Mini One Paint Issue Under Bonnet - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 1st, 2012, 02:24 PM
Local Time: 07:36 PM
United-Kingdom Mini One Paint Issue Under Bonnet
Hi There,
I am new to this forum and I am looking to purchase a used Mini One 2002. Everything on and around the car looks and sounds fine, however under the bonnet we noticed there is some discolouration with the paint on the metal work. Is this normal for this age of car or would this suggest that there is something not quite right with the vehicle e.g. been in an accident and paint work resprayed? I have HPI'ed the car and this has come back clean i.e. no write off but this does not mean to say it has not been in an accident. My other thoughts are it may have left the factory like this but as every other Mini we have seen, regardless of colour none of them have shown an issues with the paint work under the bonnet it has all been the same colour with no defects apart from this one.
I have attached some pictures and welcome anyones input.
Thank you in advance
Laura
ID:	163085   Click image for larger version
ID:	163086   Click image for larger version
Old Jan 1st, 2012, 10:15 PM
Hi
Ummm it looks like it has had paint work done but with out looking its hard to tell. May be bonnet or A pannel but with out looking its hard to tell.
I think you have two choices.
1) get a vehicle inspection done by the AA or RAC or similar and make sure you point it out to them so you are 100%
2) if you are anyway uncertain walk away there are lots of nice minis out there.
If you are a first time mini buyer have a look at the link below it will help you out.
http://www.mini2.com/forum/first-gen...first-gen.html
If you search mini2 you will find everything you need good luck and welcome I hope it all works out
Old Jan 1st, 2012, 10:22 PM
Acallahan's Avatar
MINI fanatic
Local Time: 02:36 PM
United States Male View Acallahan's Classified Ads
Have someone who knows inspect it, I would also say there is alot of heat and corrosive materials used in motors , maybe something at some point got splashed all over the inside ? just a thought.
2004 MCS JCW, 15% pulley, Dinan CAI, MSD ignition & wires, Mynes V2 header, TSW rear control arms, H-sport front and rear sway bars, H-sport lowering springs, Powerflex bushings all around, modified Forge intercooler, M7 STB , ATI Damper
Old Jan 2nd, 2012, 09:03 AM
mab01uk's Avatar
Looks ok to me like normal wear and tear, previously damaged cars are normally too shiny and prepared, most of the discolouration will probably polish out..........the underbonnet paint on Mini's is often dull/matt because it does not get the final factory applied high gloss clear lacquer coat like the outer body panels.
Old Jan 2nd, 2012, 09:44 AM
Thank you all for your repsonses. One thing that has stood out to us the more we check the photos is the discolouration actually goes under the VIN plates, which makes me think even more that it's left the factory like this or has just deteriorated over the years, what are peoples thoughts on this if they take another look at the middle photo?? This is still the best of the bunch we've seen so far and actually just off to take another look now. thanks again.
Old Jan 2nd, 2012, 10:02 AM
Hartge220's Avatar
The Anti Chrome
United Nations Male
Looking at the pics it could even be protective wax sprayed on at the factory?? If you get the chance run your finger over it & see if it feels a bit sticky
Old Jan 2nd, 2012, 05:29 PM
Thank you everyone for your advice, it looks like I am an owner of a mini, can't wait to pick it up now
Paint Under Bonnet - Comes Off Sportspack Mark First Generation Faults & Fixes 3 May 5th, 2008 10:35 PM
Paint peeling under bonnet j53 First Generation Faults & Fixes 0 Nov 20th, 2007 03:10 PM
paint damage on bonnet buggerluggs Maintenance & MINI Care 7 Jan 28th, 2006 01:40 PM
Need help or input on paint issue... Ryan M General Discussion 5 Sep 4th, 2003 03:07 AM
The whole S & black paint issue. bigbaddaboom First Generation MINI Cooper S 6 May 21st, 2002 08:33 AM
