EML Light - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 3rd, 2012, 06:11 PM
Travels's Avatar
Local Time: 07:37 PM
Female
EML Light
The EML Light came on today No power and kangerooed a few times, I contacted Mini and I've taken it straight in to the dealership and now awaiting to hear the verdict, hopefully its not bad news, Missing my Babe already.
Old Jan 3rd, 2012, 06:18 PM
mab01uk's Avatar
Usually just a sensor problem...........let us know how you get on.
Old Jan 3rd, 2012, 06:50 PM
Travels's Avatar
Female
Thanks very much, will keep you informed
Old Jan 12th, 2012, 10:40 AM
Travels's Avatar
Female
Update
Finally got my car sorted, it turned out to be the camshaft timing, which they adjusted and they also replaced the piston for timing chain tensioner.
The car is now driving like brand new
I got great service from the dealership and will be placing a post on the dealership section of the forum.
Old Jan 14th, 2012, 06:27 AM
Local Time: 10:37 PM
United Arab Emirates
DSC Light and Runflat Indicator
Hi,
I bought Mini Convertible - 2007. The run flat tires were worn out so I bought used tubeless tires however, after driving about 100 km the 'Red' Runflat indicator light has turned on.. I checked the tires pressure as well but it doesn't go off. Is it because I got Tubeless tires instead of Run flat ?
Secondly, I bought coolant from a regular gas station (confirmed with them first thou) and put it in the car. Seems like the DSC light has been on since then. Is there a link btw the two? Can it also turn on if I might have fiddled with the ASC-T switch on the dashboard ?
Thanks.. Need help as I am new to Mini world.
Old Jan 14th, 2012, 04:53 PM
Travels's Avatar
Female
Hi Saadirfan.
Welcome to Mini2.
I am sorry to hear of your problems, sorry I can't advise you but If you make a thread of your own then I am sure you will get the help you need, let us know how you get on.
Post some pic's when you can, look forward to seeing your ride.
Brake Warning Light/DSC Light all stay on and pedal goes to the floor zorro69 Wheels, Tyres & Brakes 4 Jan 10th, 2010 06:37 PM
Auto dimming interior light/ Boot Compartment LIght - not working bobnobski First Generation Faults & Fixes 2 Dec 7th, 2008 03:55 PM
Chrome Line Interior for Hazard Warning Light and Display Light Buttons matt1584 First Generation Interior & Ice 1 Mar 18th, 2005 08:18 PM
Alta Rally Light Bar or MINI Sport Light Lamp Bar dinlo First Generation MINI Exterior 19 Oct 18th, 2004 08:39 AM
Is High stop light included in clear rear light kit mmmini First Generation MINI Cooper S 3 Aug 8th, 2002 05:44 PM
