Gear box - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 7th, 2012, 08:43 PM
Mini 2002 R50
Local Time: 08:33 AM
Australia Male
Australia Gear box
Hi!
So I've got a niggling issue with my 2002 R50 Mini Cooper.
When I put the stick into reverse, it doesn't go all the way in. I need to lift the clutch slightly to get it into gear. If I touch the accelerator, it grinds the gear.
On start-up, it's sometimes the same putting it into 1st, but not when driving (usually).
I know it's a tight gearbox, but is this normal??
It's my first car.
Thanks!
Old Jan 7th, 2012, 11:21 PM
Local Time: 11:33 PM
Hi
I think you may be having the dreaded midland gearbox issues .
If you do a few searches here at mini2 about midland gear boxes they may help
I would say first make shore the gear shift linkages are all ok first no slack or wear in the system .
But to be honest it sounds like the gearbox needs a overhaul/repair
MINI Cooper Forum - MINI2 Mini Cooper Forums - FAQ & DIY: General MINI FAQs and Advice
This link will tell you about the models,years and changes
You can get a kit If it turns out to be the GB
http://www.ebay.co.uk/sch/i.html?_fr...All-Categories
Also some guys had swaped ther midlands to Getrags
http://www.minitorque.com/forum/f275...onversion-602/
Anyway I do hope it's not the GB sorry I could not be more helpfull
Tags: , , , , , ,
Mini Cooper gear not engaging [ automatic gear box] mkoolb General Discussion 10 Oct 3rd, 2011 10:23 AM
Lost 5th gear and reverse? Gear Shift Cables? samwhunt First Generation Faults & Fixes 0 Aug 4th, 2011 02:13 PM
2007 MINI COOPER R56 sticky gear change 1st to 2nd gear hankdu Second Generation MINI Cooper 1 Aug 31st, 2008 08:17 PM
Gear stick/Gear knob question PfXwlSt Second Generation Faults & Fixes 1 Apr 26th, 2008 08:16 PM
Gear-stick vibrates wildly in 1st gear? waynef First Generation Faults & Fixes 41 Apr 29th, 2004 10:26 PM
