Main Beam staying on Mini One R50 - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 14th, 2012, 09:21 PM
MGFmad's Avatar
Local Time: 11:34 PM
Discovered a problem with the main beam tonight, switching on the main beam is fine by pulling the stalk towards the wheel but when doing the same action to switch the main beam off, the headlights stay on and the warning light on the dash also stays on. Only way to get it to go off is to push the stalk back manually. Then it comes back on again when the indicators are used and again requires to be pushed back manually to switch it off.
I am guessing the stalk is worn but wondered if there is any other cause
Old Jan 15th, 2012, 10:28 PM
MGFmad's Avatar
An update - I sprayed some WD40 into the stalk mechanism and its working fine now Will be interesting to see how long it lasts!
Old Jan 16th, 2012, 12:50 AM
rieste's Avatar
MINI ONE
It may have just been dirty, if it is you have probably cleaned it off. I hope it's sorted!
New Mini - 57 plate: Main Beam beddingm Second Generation Faults & Fixes 13 Oct 29th, 2011 09:36 PM
Can you use main & dipped beam together mike58 Second Generation MINI Exterior 8 Nov 13th, 2007 11:14 AM
Spotlight with main beam robh964 First Generation MINI Exterior 10 Dec 8th, 2006 05:39 AM
Main Beam problems matada34 First Generation Faults & Fixes 3 Feb 6th, 2006 07:45 PM
Dodgy main beam Mini Cruiser First Generation Faults & Fixes 11 Dec 24th, 2002 02:11 PM
