popping noise bumps sunroof 07 - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 22nd, 2012, 05:41 PM
Local Time: 10:35 PM
Unhappy popping noise bumps sunroof 07
My 07 mini has developed the most annoying popping / cracking noise when going over bumps in the road only when the sunroof is fully closed... if i open it slightly on a tilt then the noise is gone!
I've tried grease, opening and shutting it hundreds of times ... occasionally it goes away for a day but then its back again.
its such a loud popping noise that it can be heard over the radio which is annoying.
I tried shutting the guards but that made no difference. Any advice ? I'm sure it's a simple fix but I cant find where to start.. I don't want to have to go to the dealer as I'm forever going there and its becomming expensive..
the noise comes from the left passenger side.
Annoying noise when going over small bumps at low speed tony168 First Generation Faults & Fixes 3 Jan 5th, 2009 09:21 PM
Noise going over bumps! sportdan First Generation Faults & Fixes 6 Nov 30th, 2007 05:42 PM
Popping noise under the hood? Mister First Generation Faults & Fixes 0 Sep 14th, 2006 03:13 PM
noise from rear over hard bumps Beecher First Generation Faults & Fixes 5 Jan 8th, 2006 07:25 PM
How do you get that spluttering and popping noise monkeynuts First Generation MINI Tuning 22 Jun 4th, 2004 09:39 PM
