gear box - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jan 27th, 2012, 02:22 PM
Local Time: 11:35 PM
United Kingdom Male View m14off's Classified Ads
gear box
Hi new here already said hi in new members area
I only just picked up my mini cooper s and on way back it did seems stiff putting it up the gears, i dont know much about cars or the mini and was wondering if this is normal or an issue?
it goes in to gear no issue pulls fine no slip if this helps?
thanks again for any help
Old Jan 27th, 2012, 04:45 PM
mab01uk's Avatar
Online
It may be that the gearlever selector cables and or linkages need some lubrication which is not unusual. Even replacement of the cables themselves is not a big job if necessary. A change of gearbox oil also often helps even though BMW say their gearboxes are 'filled for life', it will also extend the life of the gearbox outside of any warranty.
Old Jan 29th, 2012, 06:01 PM
Thanks for the info the car has been stood for months I wonder if that's the issue, will take it to garage and see what they say )) hope its ok ..
Mini Cooper gear not engaging [ automatic gear box] mkoolb General Discussion 10 Oct 3rd, 2011 10:23 AM
Lost 5th gear and reverse? Gear Shift Cables? samwhunt First Generation Faults & Fixes 0 Aug 4th, 2011 02:13 PM
2007 MINI COOPER R56 sticky gear change 1st to 2nd gear hankdu Second Generation MINI Cooper 1 Aug 31st, 2008 08:17 PM
Gear stick/Gear knob question PfXwlSt Second Generation Faults & Fixes 1 Apr 26th, 2008 08:16 PM
Gear-stick vibrates wildly in 1st gear? waynef First Generation Faults & Fixes 41 Apr 29th, 2004 10:26 PM
