Buying a new mini - what should i check for - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old May 26th, 2012, 07:04 AM
Local Time: 05:46 PM
United Kingdom View scg1889's Classified Ads
Hi guys
Thinking of entering into the mini world most likely via a 52 Cooper S what are the main things to check for, and what should i look for in the service history, guessing it's going to have 80k upwards on the clock.
Have had a scour round the site for links and read the AROnline which was pretty good but anymore info gladly welcomed
Si
Old May 26th, 2012, 07:32 AM
mab01uk's Avatar
This USA based Mini Buyers Guide is also quite a useful reference:
MotoringFile MINI R50/R53 Buyers Guide
Old May 26th, 2012, 10:11 AM
one of the best things you can do is go for a test drive, take it through the gears listen for anything untoward. be careful with the first gen S's they have been known to have some problems! at 80k miles should be ok though! be sure to check if any timing belt changes etc as if not your probably going to have to payout for that sooner rather than later! hpi check might be a good idea aswel!
hope this helps!
Old May 26th, 2012, 06:35 PM
Acallahan's Avatar
MINI fanatic
Local Time: 12:46 PM
United States Male View Acallahan's Classified Ads
Be sure to check power steering pump and crank pulley , there are other things to check but those are 2 big ones . The belt tensioner comes to mind also.
2004 MCS JCW, 15% pulley, Dinan CAI, MSD ignition & wires, Mynes V2 header, TSW rear control arms, H-sport front and rear sway bars, H-sport lowering springs, Powerflex bushings all around, modified Forge intercooler, M7 STB , ATI Damper
Old May 26th, 2012, 07:22 PM
Tigger, Eeyore & Roo's Avatar
Focus RS & Land Rover FL2
United Kingdom View Tigger, Eeyore & Roo's Hyper Blue & White 1st Gen MINI Cooper S Profile View Tigger, Eeyore & Roo's Classified Ads
Be very careful when following advice about carry out timing belt and timing belt tensioner changes, as your engine won't have either. Attempting to change items that aren't fitted to an engine may cause injury, death or (in the worst cases) having the pi** taken out of you by the service receptionist.
You have been warned.
May '04 - Feb '07 R50, Feb '07 - May '10 R53. Enjoyed our time with MINI's, but ran out of space! Now Focus RS & Land Rover powered...
What do I need to check for in buying a used Mini Cooper dogboy Maintenance & MINI Care 3 Aug 27th, 2010 01:51 PM
Check out my new mini!!! jamesw24 Models Collectables & Collectibles 14 May 14th, 2008 06:43 PM
Mini Maintenance Check atif_farooq Maintenance & MINI Care 3 Aug 21st, 2006 07:12 PM
Things to check when buying used Cooper S? Have First Generation MINI Cooper S 6 Mar 24th, 2006 10:26 AM
HPI Check on used mini? hamd01 General Discussion 3 Jun 23rd, 2003 04:41 PM
