Ac not working on mini one 2001 garage says they dont know whats wrong with it - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Jun 3rd, 2012, 11:36 AM
steveolondon's Avatar
Local Time: 03:32 PM
United-Kingdom Ac not working on mini one 2001 garage says they dont know whats wrong with it
Ok so my Ac stopped working th other day, so i presumer it needed refilling, booked it into they filled it up and said it still don't work, so they looked over the car and done a full diagnosis Test for free and said they found nothing wrong with the AC no leaks no nothing and that they didn't know what was wrong with it. suggestions and thoughts are more than welcome please help.Click image for larger version
Old Jun 3rd, 2012, 12:03 PM
Online
Well what an excellent garage, hope youre not going to use them for anything else then?
If the system is filled, no leaks and it still doesnt work, might be the compressor not engaging when you press the air con button, but if they did a FULL? diagnosis this is fairly obvious.
Mind you they did a free test didnt they, so perhaps they do a better job if you pay, who knows?
Old Jun 3rd, 2012, 08:03 PM
Hi,
I to had a similar problem with lack of decent AC, as you may know AC deteriorates with age and should be topped up; I made the obvious mistake of going to a Kwik Fit although as they were unsuccessful they did not charge and put me in touch with an auto AC specialist, he was quoting over £500 for major works. For some reason I thought I’d give someone else a go and found a MINI/BMW independent specialist, he explained that most don’t refill the system properly and this will show as a failure, I left it with him and hey presto the car is cold again!
Old Jun 4th, 2012, 01:52 PM
many thanks for the reply i think I'm gonna take in to BMW and see what they say, i ooh it to Halfords as i presumed it needed refiling and thats what i paid for, however Halfords offer a diagnosis for any car for free i believe, but i guess sum times u get what u pay for, and in Halfords defence they did seem pretty legit about the fact they could find anything wrong with and suggested i take it somewhere else, which is obviously kinda weird hearing that from a garage. they did mention before if i needed a new pump it would be £500 however he said thats working fine. how much did it cost to sort the problem with BMW (as a ball park figure) I'm aware prices fluctuate depending where u live.
Old Jun 22nd, 2012, 02:17 PM
Local Time: 10:32 AM
I presume it is your a/c compressor not turning, have you checked?
If the refrigerant pressure is ok, check with your garage what the reading was, it could be electrical / relay / fuse, check those.
A common problem with the ac compressor is the electrical clutch that is mounted on the end fails. On many cars you can get a replacement clutch, not from Mini from the factory. There is an aftermarket one in the US that works great. It is a much cheaper alternative to replacing the compressor, drier, etc.
Have a look here..
northamericanmotoring.com/forums/r50-r53-hatch-talk-2002-2006/228481-r53-a-c-problem-detailed.html]R53 A/C Problem (detailed) - North American Motoring
In the line above add in the w w w .
Old Jun 22nd, 2012, 04:44 PM
shorn's Avatar
Local Time: 08:32 AM
If the clutch is not engaged, check the electricals to it. You should see 12V to the clutch winding/coil. If the volts are there but the clutch is not engaged suspect either a open clutch winding or... there are 2 diodes in the clutch (has to be removed to see them); one in series with the winding; one in parallel. The diodes, especially the series one, go bad - opens so that no current will flow. Replace the diodes or replace the entire clutch.
Old Jun 22nd, 2012, 05:53 PM
Local Time: 02:32 PM
United Kingdom Male View designer_label's Classified Ads
You need a proper garage to diagnose the problem.
If its a leak they will put something in to find the leak and stop it or it could be the condensor that needs replacing.
Bmw charge £66 to diagnose an air conditioning problem!
I know that the air con drain should be checked very year or so but I cant find it?
2001 mini cooper dashboard lights not working daisydurrant First Generation Faults & Fixes 1 Oct 3rd, 2010 09:29 AM
whats wrong with everybody ! j.d General Discussion 27 Oct 7th, 2009 05:37 PM
Whats wrong with an MCS?? JAMIE1131 General Discussion 181 Jun 26th, 2007 08:05 PM
Whats wrong with my Mini?!! MiniPetrolHead First Generation MINI One 9 Dec 29th, 2006 04:20 PM
Dont take this the wrong way... MrWhoa First Generation MINI Cooper S 14 Jul 17th, 2003 09:06 PM
