2003 Cooper S oil leaking - MINI Cooper Forum
post #1 of 6 (permalink) Old Jun 28th, 2012, 09:37 PM Thread Starter
Local Time: 06:12 AM
My Cooper S (2003) with 138,000 miles developed a oil leak.
Does it look serious?
Thanks for your time.
David
ID:	164308   Click image for larger version
ID:	164309   Click image for larger version
ID:	164310   Click image for larger version
ID:	164311   Click image for larger version
chideloh is offline
post #2 of 6 (permalink) Old Jun 28th, 2012, 11:32 PM
clubMINI Master
rellik666's Avatar
Local Time: 09:12 PM
Australia Female View rellik666's Pepper White & Black 1st Gen MINI Cooper S Convertible Profile
Send a message via MSN to rellik666 Send a message via Skype™ to rellik666
Can't really tell from those pics, but it could be a number of things.
Thermostat, most likely, will need replacing.
One of the engine gaskets, could be an easy fix or could need replacing.
Nothing life threatening but could be a few $$$$
Australia - The party is coming - check it out now
rellik666 is offline
post #3 of 6 (permalink) Old Jun 29th, 2012, 05:32 AM
Local Time: 11:12 AM
Quoted: 53 Post(s)
Bit difficult to tell from those, the position of the drip is not necessarily where the leak is, the oil will just run to the lowest point that side.
The Nun is offline
post #4 of 6 (permalink) Old Jun 29th, 2012, 11:03 PM Thread Starter
I cant see any leak from the top. Can it be the drip pan gasket?
chideloh is offline
post #5 of 6 (permalink) Old Jun 29th, 2012, 11:15 PM
Caveman's Avatar
Local Time: 12:12 PM
Quoted: 83 Post(s)
Caveman is offline
post #6 of 6 (permalink) Old Jul 1st, 2012, 03:13 AM Thread Starter
Thank you Caveman
chideloh is offline
Leaking roof on Cooper S Convertible HELP!! JK101 First Generation Faults & Fixes 0 Sep 30th, 2010 05:41 PM
leaking coolant on cooper parklaneuk First Generation Faults & Fixes 4 Mar 7th, 2010 09:16 PM
Leaking cooper convertible northk First Generation Faults & Fixes 6 Jun 2nd, 2008 08:36 AM
Leaking roof 06 cooper converitble binchybabes First Generation Faults & Fixes 5 Jan 30th, 2007 05:16 PM
Leaking Engine Mounts in Cooper S BENJ First Generation Faults & Fixes 1 Aug 18th, 2006 10:23 AM
