battery light - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Nov 6th, 2012, 03:44 PM
Local Time: 09:39 PM
United Kingdom Female
United-Kingdom battery light
my battery light decides wen it wants to, it randomly flashes... any ideas?
Old Nov 6th, 2012, 04:22 PM
Online
Dodgy Alternator?, or probably a slipping alternator drive belt especially in wet/damp weather if the belts worn or not adjusted tight enough?
Old Nov 11th, 2012, 04:15 PM
my main clock has Also started to turn itself off, lights are slightly flickering, when the battery light flashes it revs every so slightly
Old Nov 11th, 2012, 06:24 PM
Online
Revs go up because its stopped charging when the light is on.
Could still be a drive belt problem, and its worth checking the electrical connections to the alternator are clean and secure but could also be a diode problem in the alternator meaning its could be on its last legs.
Check the engine earth strap is in good condition and fixed securely too.
