Turbo blown? - MINI Cooper Forum - MINI2 Mini Cooper Forums
Old Feb 6th, 2013, 04:24 PM
Local Time: 07:44 AM
Cool Turbo blown?
Last night on the way home my 08 Cooper S temperature light came on, then an oil light.. I pulled over and opened the hood and noticed my turbo was orange with heat! WTF!! I could understand if I was driving like a maniac, but I was just cruising... Anyone know what the deal is and how much this will cost to be repaired?
Old Feb 6th, 2013, 08:28 PM
Local Time: 02:44 PM
sounds like you ran low on oil so the turbo was starved of oil causing it to heat up, you might be lucky and the bearings might be ok - only way to check would be checking for play in the shaft of the turbo.
Old Feb 7th, 2013, 01:06 AM
just got off the phone with the shop.. they said the thermostat housing somehow disintegrated and all the coolant leaked out.. also it made a turbo oil line burst and all of the oil also dumped.. i was quoted $1182.00 to fix. Is that reasonable?
Old Feb 7th, 2013, 12:15 PM
Depends a little on whether you stopped the engine in time so the oil/coolant loss hasnt caused that any damage too??
Old Feb 15th, 2013, 01:12 PM
United Kingdom Female
Ive just had mine replaced and it cost £900, £500 for a new (or remanufactured) turbo, plus all the oil pipes to ensure it doesnt happen again.
It had oil changes as often as mini recommended so I was pretty ****ed off when I had to pay that!!!
