| airbag fault Hi All
wonder if ny one has any advice on this,
Mini copper fault is a 56 plate with airbag light on and showing a fault code of 93A8 drivers side airbag stage 1,
Also with the same vehicle the horn goes off on its own!! and i have had to disconnect horn, not sure if the fault is related to the airbag one, thought it may be clock spring.
Rgds steve
Reason: incorrect wording
