Can anyone help me?
I recently had a new clutch fitted and also had the battery recharged because it was left in the driveway for a number of weeks unused.
The problem I have now is with the original key I used before with no problem now will not arm disarm alarm or open close door use the key fob .
I rang bmw and they gave me code to use which is as follows :
* open door mnually -close door
* turn ignition to posistion number one
* take key out hold middle key and press top key 3 times in sucsession
* the locks should then lock and unlock once
job done..
I tried this several times with no sucssess
I went to bmw service/ parts centre with the problem and asked for further advice and told them what was going on bottom line they want £130.00 of me for a new key they said that the charging circuit is dead ?
Is this is the case seems a lot for recoding a key.
Cheers.
