xenon lights? - MINI Cooper Forum
Go Back   MINI Cooper Forum > All Models & Variants > General Discussion
Retrofit 25-watt xenon headlamps mab01uk MINI in the Media 1 Sep 9th, 2013 01:44 PM
Official retrofit of xenon headlights Angib General Discussion 0 Sep 3rd, 2013 04:24 PM
R56 Xenon lights how much they worth? DrRollo General Discussion 3 Jul 23rd, 2013 09:02 AM
Xenon Lights Problem minimadmunday Maintenance & MINI Care 2 Dec 29th, 2012 10:52 AM
Old Dec 3rd, 2013, 12:13 AM
Local Time: 01:30 PM
xenon lights?
I have an 09 mini and am wanting to go to hid xenon lights.Dealer price is ridiculous. Are there any aftermarkets that work
Old Dec 3rd, 2013, 10:57 PM
HELP needing this for Christmas gift
Old Dec 4th, 2013, 08:18 AM
Keano's Avatar
JCW 250
Local Time: 07:30 PM
United Kingdom Male View Keano's Solid Black & Body Color 1st Gen MINI Cooper S Profile View Keano's Classified Ads
Personally I would only get OEM. In the UK, there are other bits you need to fit for xenons to be road legal and its a big fuss unless you can retrofit everything you need either from dealer parts or a breakers yard...
HIDs in reflector lamps will blind people so it needs to be a full upgrade IMO.
Buying yourself an xmas gift? Lucky you ::
Running 211whp
Old Dec 4th, 2013, 11:32 PM
Actually it is my daughter's car. She wants bright blue lights for Christmas and I cant afford Mini stock price!!
Old Dec 5th, 2013, 02:52 AM
United Kingdom Male View Blusox's Laser Blue & Body Color 1st Gen MINI Cooper S Profile View Blusox's Classified Ads
HID Projectors from The Retrofit Source Inc
Try these guys, they may have something that will fit the 09 mini headlamps
Old Dec 5th, 2013, 10:35 PM
Smile
Thanks Blusox ordered a set today. Thanks again
Old Dec 6th, 2013, 04:08 PM
beken's Avatar
Send a message via ICQ to beken Send a message via MSN to beken Send a message via Yahoo to beken Send a message via Skype™ to beken
Local Time: 11:30 AM
Canada Male View beken's Black-Eye Purple & Body Color 1st Gen MINI Cooper S Profile
Silverstar bulbs are pretty white.
05MCS BEP Alta 22mm rear anti-swaybar, Madness CAI, Alta 15%, NGK BRK7EIX, M7 Strut Tower Reinforcement plates, BSH Lower Engine Mount
Old Dec 7th, 2013, 11:48 AM
Glad to have helped. I'm in the UK, but I've used them before for projects on other cars. Keep meaning to see if they have anybody xenon projectors to fit the R53 xenon lights.
Old Dec 14th, 2013, 06:00 AM
Local Time: 06:30 PM
Do xenon light bulbs require conversion kits?
I have stock headlights and i want to make the lights brighter. However I dont want to buy a HID conversion kit. I see Xenon light bulbs on ebay and at local auto stores. Do xenon bulbs require conversion kits or are they plug and play? also i want to do this to my foglights, but i dont know if i have to buy special bulbs for that too
Old Dec 14th, 2013, 08:39 AM
Deep_27a's Avatar
...opinionated!
United Kingdom Male View Deep_27a's  &  2nd Gen  Profile View Deep_27a's Classified Ads
Keano is spot on here, OEM Xenon headlamps are not plug and play, bulb or unit.
In the UK at least, they require headlamp washers to be legal so you will need the kit for that too. They also require the levelling system to work, both of these are MOT failures now, didn't used to be.
Also, the wiring loom is different and additional control units for the above to work are needed.
Old Dec 14th, 2013, 07:55 PM
Best way to get xenons is to buy a car with them factory fitted I'm afraid.
Old Dec 15th, 2013, 08:03 PM
Germany Male
Hey check Ebay, many after market head light for cheap prices with E1 and more regulation levels.
Old Dec 15th, 2013, 08:31 PM
I recently fitted HID`s to my 09 Cooper D and had a bit of a nightmare.
I have bought 5 sets of HID`s for previous cars without any real problems.
I bought the TERMINATOR HID`s from HID`s Direct (who have always been great with me). I live nearby so was able to collect.
When I bought, the shop said that there may be a problem with the CANBUS system on the car, which may throw up an error message. Sue enough, when I fitted them, whilst they looked great, it throw up an error message every time the car started.
The bulb you need is a H4 type Xenon bulb (dual filament so Bi Xenon - high beam and low beam). I got the 6000k bilb which is the bright white light. If you want the blue, go for the 8k or 10k. I paid 65 for mine
Be aware that on the box, it clearly states that they are not for road use. So you may struggle at MOT time.
On the Mini they are so easy to fit (take about 20 mins total). They come with what is called a Ballast and other wiring, but basically take the place of the original bulb and are fitted in line. They really are very simple to fit.
The improvement in the lighting is terrific and no one flashed me, so I assume I was not dazzling. That said, one of the lights did stop working (after about 4 weeks). So I took them back to the shop and they gave me my money back. I purchased some Osram (I think called night view) bulbs, which were a simple replacement (20).
Now no warning lights and whilst not as good vision, I know that it will pass the MOT.
Also, be aware, with the stop/start. Every time it restarted, the Xenon bulbs used to flash. Bit disconcerting for other road users.
Hope this helps.
Old Dec 16th, 2013, 11:17 AM
Keano's Avatar
JCW 250
The whiter halogens are crap - not worth trying. As they go whiter / bluer / purple () the light levels drop so whilst it may look nicer, you wont be able to see where you're going
I tried a set on my BMW to see how bad they were and I found myself using other cars headlights to see where I was going and so swapped back immediately.
To get xenon light level output you need xenons - otherwise get the best halogens you can
Also, if you fit a xenon bulb in a standard halogen light, it wont work
Running 211whp
» Recent Threads
Mini One dipstick
Apr 14th, 2014 04:22 PM
by pooz23
Last post by mab01uk
Today 06:15 PM
5 Replies, 233 Views
Facelift ('05) Confusion
Today 05:26 PM
by Triang
Last post by Triang
Today 06:02 PM
2 Replies, 25 Views
High Mileage 152k miles - Mini One 04 plate
Jan 31st, 2014 09:43 AM
by raym
Last post by Triang
Today 05:46 PM
8 Replies, 1,394 Views
Facelift One ('05) Confusion...may have posted in wrong place sorry!
Today 05:37 PM
by Triang
Last post by Triang
Today 05:37 PM
0 Replies, 14 Views
Mini Identification
Today 10:23 AM
Last post by subframe
Today 05:21 PM
8 Replies, 145 Views
Roof Rack
Today 03:17 PM
by vnutz
Last post by vnutz
Today 03:17 PM
0 Replies, 43 Views
Trunk Handle Cover
Today 02:39 AM
by iamtony
Last post by whaap
Today 12:24 PM
2 Replies, 110 Views
O2 sensors in exhaust
Apr 18th, 2014 06:03 PM
Last post by marque
Today 11:03 AM
3 Replies, 211 Views
Will this rear bike rack work on the Clubman?
Jun 6th, 2011 10:18 PM
Last post by tina
Today 07:40 AM
4 Replies, 4,023 Views
Mini Cooper S Rebuild
Apr 18th, 2014 07:49 AM
Last post by tina
Today 07:39 AM
1 Replies, 171 Views
R52 A pillar interior trim removal
Apr 18th, 2014 08:11 AM
Last post by tina
Today 07:39 AM
4 Replies, 203 Views
can anybody tell me what this is
Apr 15th, 2014 08:02 PM
by Jon g
Last post by tina
Today 07:38 AM
2 Replies, 286 Views
MINI of Burlington
Mar 30th, 2014 08:59 PM
Last post by tina
Today 07:37 AM
1 Replies, 296 Views
Just bought mini what extras do I need to tell insurance about
Mar 19th, 2014 03:51 PM
Last post by tina
Today 07:36 AM
8 Replies, 723 Views
Cup holder inserts
Apr 18th, 2014 06:23 PM
Last post by tina
Today 07:35 AM
5 Replies, 240 Views
Should i buy a Mini Cooper r50
Feb 14th, 2012 01:09 AM
by MENESS
Last post by Milpol
Today 12:58 AM
13 Replies, 7,963 Views
Replacement driver side door handle **new member**
Apr 14th, 2014 10:32 PM
Last post by The Nun
Yesterday 06:43 PM
3 Replies, 276 Views
Drivers Selt Belt PreTensionor / AirBag Fault Light
Yesterday 12:20 PM
Last post by da8addick
Yesterday 12:20 PM
0 Replies, 143 Views
Black rims for 195/55r16 run flats?
Mar 2nd, 2014 03:59 AM
Last post by habi222
Yesterday 12:18 PM
1 Replies, 390 Views
Tyre Sizes
Feb 17th, 2014 10:32 AM
by danb76
Yesterday 12:00 PM
3 Replies, 616 Views
Wheel & Tire Center
