2004 Mini Cooper S Heater Issue - MINI Cooper Forum
Go Back   MINI Cooper Forum > All Models & Variants > General Discussion
2014 MINI Cooper Hardtop Revealed AutoGuide.com MINI News 12 Feb 12th, 2014 02:12 PM
04 Mini cooper S issue a stallion First Generation MINI Tuning 2 Feb 21st, 2013 10:04 PM
2004 Mini Cooper S sarez Welcome New Members 2 Feb 11th, 2013 10:17 PM
"New" 2004 Mini Cooper S Ethica Welcome New Members 6 Dec 10th, 2012 04:37 PM
Old Dec 6th, 2013, 12:55 AM
Local Time: 09:20 PM
Hello all,
I saw a few posts about heating issues, but no one seemed to pinpoint the issue I’m having with my cooper.
I am getting no heat at all from my cooper. I wanted to mention that when I put the heat on auto & HI or a high temperature the fans do not kick in. I can manually hit the “fan +” button and have it blow cold air. The AC is working.
I've checked the coolant level and it was barley under the “MIN” level. I filled it up to max and haven’t noticed any decrease in coolant for over a week with no heat still.
I've also checked all of my fuses listed below and they are all good.
• F21
• F29
• F30
• F31
• F40
There is no leakage in the cabin of the car near the heater core. The engine temp stays at half with no overheating. I don’t hear anything funny under the hood and don’t smell anything in the cab.
I think it might be a partially blocked heater core, but I wanted some second opinions.. thoughts?
Old Dec 7th, 2013, 03:16 PM
mab01uk's Avatar
Local Time: 10:20 PM
If you remove the black plastic side panel cover (3 screws I think) to the heater box assembly down in the passenger footwell (on centre console side) behind you will find the flow and return pipes into the side of the heater matrix radiator (from the engine compartment)......are they both hot? In pipe/hose should be slightly hotter than the return and matrix rad should be hot.......there have been a few cases of a blocked matrix causing this problem here on Mini2. Lack of circulation flow meaning no heat, can also be caused by an airlock requiring bleeding of cooling system.
Old Dec 7th, 2013, 06:55 PM
Thanks for the reply! I have not does this, and i will be able to probably tomorrow. I guess it should be noted that i did replace my coolant reservoir over the summer and did not bleed any coolant. Does this sound like it may be the issue?
Old Dec 7th, 2013, 11:20 PM
Flushed.
I just had my coolant flushed by a local mechanic. I still have no heat. I assume the issue is the heater core at this point? Thoughts?
Old Dec 8th, 2013, 09:06 AM
mab01uk's Avatar
If he has flushed and bleed the system correctly then the next thing to check is if hot water is getting to the heater matrix and circulating through it. Removing the plastic side panel should allow you to feel if there is heat at that point. Sometimes the heat is there but on switching the heater fan on it quickly cools due to lack of circulation in a partially blocked matrix.
Replacing the heater matrix is not a big job but can be a bit fiddly with hose clamps, etc and bleeding any air out afterwards.......there should be a couple of guides on Mini2 if you search.
Heater Core Replacement:
http://www.northamericanmotoring.com...placement.html
Old Dec 12th, 2013, 12:29 AM
New Heater core
New heater core corrected the issue. I referenced youtube for a little help. Thanks for the assistance!
Tags: , ,
» Recent Threads
2007 Cooper D (r56) - weird sound. Maybe clutch?
Today 07:01 PM
by hyvrid
Last post by hyvrid
Today 09:20 PM
2 Replies, 49 Views
How to Retrofit the Spacesaver Spare Wheel
Dec 6th, 2011 10:40 PM
by mab01uk
Last post by scooper dooper
Today 09:19 PM
45 Replies, 29,485 Views
Facelift ('05) Confusion
Today 05:26 PM
by Triang
Last post by JohnnyC
Today 08:58 PM
6 Replies, 109 Views
2007 Cooper D (r56) - How to look after her and what to look for when buying
Apr 15th, 2014 01:10 PM
by hyvrid
Last post by hyvrid
Today 08:11 PM
7 Replies, 410 Views
Trunk Handle Cover
Today 02:39 AM
by iamtony
Last post by iamtony
Today 08:04 PM
3 Replies, 128 Views
O2 sensors in exhaust
Apr 18th, 2014 06:03 PM
Last post by Invernessguy
Today 07:22 PM
4 Replies, 222 Views
Mini One dipstick
Apr 14th, 2014 04:22 PM
by pooz23
Last post by drozd
Today 07:06 PM
6 Replies, 261 Views
High Mileage 152k miles - Mini One 04 plate
Jan 31st, 2014 09:43 AM
by raym
Last post by Triang
Today 05:46 PM
8 Replies, 1,409 Views
Facelift One ('05) Confusion...may have posted in wrong place sorry!
Today 05:37 PM
by Triang
Last post by Triang
Today 05:37 PM
0 Replies, 84 Views
Mini Identification
Today 10:23 AM
Last post by subframe
Today 05:21 PM
8 Replies, 165 Views
Roof Rack
Today 03:17 PM
by vnutz
Last post by vnutz
Today 03:17 PM
0 Replies, 67 Views
Will this rear bike rack work on the Clubman?
Jun 6th, 2011 10:18 PM
Last post by tina
Today 07:40 AM
4 Replies, 4,030 Views
Mini Cooper S Rebuild
Apr 18th, 2014 07:49 AM
Last post by tina
Today 07:39 AM
1 Replies, 175 Views
R52 A pillar interior trim removal
Apr 18th, 2014 08:11 AM
Last post by tina
Today 07:39 AM
4 Replies, 212 Views
can anybody tell me what this is
Apr 15th, 2014 08:02 PM
by Jon g
Last post by tina
Today 07:38 AM
2 Replies, 296 Views
MINI of Burlington
Mar 30th, 2014 08:59 PM
Last post by tina
Today 07:37 AM
1 Replies, 301 Views
Just bought mini what extras do I need to tell insurance about
Mar 19th, 2014 03:51 PM
Last post by tina
Today 07:36 AM
8 Replies, 732 Views
Cup holder inserts
Apr 18th, 2014 06:23 PM
Last post by tina
Today 07:35 AM
5 Replies, 247 Views
Should i buy a Mini Cooper r50
Feb 14th, 2012 01:09 AM
by MENESS
Last post by Milpol
Today 12:58 AM
13 Replies, 7,971 Views
Replacement driver side door handle **new member**
Apr 14th, 2014 10:32 PM
Last post by The Nun
Yesterday 06:43 PM
3 Replies, 280 Views
