How do I open tailgate when battery is flat? - MINI Cooper Forum
Go Back   MINI Cooper Forum > All Models & Variants > General Discussion
AGM Battery markslater Second Generation Faults & Fixes 5 Dec 21st, 2013 07:01 AM
Battery Advice Oldpaint Maintenance & MINI Care 2 Aug 30th, 2013 10:22 AM
Constant beep from speedo and battery going flat????? bigbenn36 First Generation Faults & Fixes 3 Mar 25th, 2013 10:26 AM
Cooper not starting, flat battery? READ ON colinthecooper First Generation Faults & Fixes 3 Mar 19th, 2013 11:32 PM
Old Dec 6th, 2013, 08:38 AM
grizzlybiker04's Avatar
Local Time: 12:00 AM
One question
I want to remove the battery from the car and on the R53 its in the tailgate.
..but with a flat battery, I cannot open the tailgate - is there a manual method ?
Background
I have the dreaded PSP problem and when I connected an old battery charger to the places under the bonnet - the charger failed. The PSP problem means that the power steering pump is permanently on and this I think is caused the battery charger to blew up (well actually just stopped working).
I have just bought a workshop style charger with 100 amps starting power so this will probably be fine but -- just to be sure - is there any way I can open the tailgate when the battery is flat so central unlocking does not work ?
Old Dec 6th, 2013, 09:34 AM
You are number 6
Send a message via Skype™ to Mike Clarke
Local Time: 08:00 AM
Australia Male View Mike Clarke's Solid Black & Body Color 1st Gen MINI Cooper S Profile
Lift up the rear seat and if you are lucky there will be a cable pull that will release the tailgate. You might need a second person at the tailgate otherwise by the time you get from the back seat to the tailgate it could have latched again.
Old Dec 6th, 2013, 11:06 AM
Australia
Bonza, Thank you
Old Dec 6th, 2013, 11:45 AM
mab01uk's Avatar
Local Time: 01:00 AM
Don't allow the psp to run continuously or it will overheat, boil the ps fluid and damage the seals in the steering rack.....worst case it will catch fire! Always disconnect the battery when unattended until the pump is replaced or reconditioned.
Old Dec 6th, 2013, 12:33 PM
mab01UK,
Thank you, much appreciated. I can see you know about the PSP issue. Can I ask:
When I lift up the rear seat - the bit that one sits on - there is no cable pull that I can see (unlike my previous car) - should there definitely be one there ? Or might it be behind that part of the seat that one's back rests against ?
Is there another way I can open the tailgate when the battery is flat ?
John Tee / Mini Gearboxes in Coventry have indicated a great price for supply & fit of a replacement PSP. I have used them before and they did a good job..... but I am worried about driving the mini (R53) to Coventry with this problem. Do you know of any mechanic / garage nearer than Coventry - er like in London, please ?
Old Dec 6th, 2013, 12:46 PM
I thought that you lowered the rear seat backs and embedded in the tailgate there is some sort of handle that you just have to pull. Well there is on my convertible.
Old Dec 6th, 2013, 02:25 PM
Thanks guys - I cannot see how to lower the seat backs on my 52 Mini cooper S (R53).
I wonder if anyone else can suggest how I can open my tailgate (boot) when the battery is dead flat, please ?
I have tried removing fuse F39, then trying using the under-the-bonnet jump lead points to charge to but I have an "intelligent" charger whcih just shows "ERR". I worry that some of the electrics have been fried by the PSP - running until it killed the battery.
So, in any event, I am still keen to open the tailagte manually (that is non electrically).
Old Dec 6th, 2013, 03:28 PM
Caveman's Avatar
Local Time: 02:00 AM
Quote: Originally Posted by grizzlybiker04 (original)
When I lift up the rear seat - the bit that one sits on - there is no cable pull that I can see (unlike my previous car) - should there definitely be one there?
If the car was built prior to October 2002 it won't have a manual boot release (unless one was retrofit).
Old Dec 6th, 2013, 04:07 PM
beken's Avatar
Send a message via ICQ to beken Send a message via MSN to beken Send a message via Yahoo to beken Send a message via Skype™ to beken
Local Time: 05:00 PM
Canada Male View beken's Black-Eye Purple & Body Color 1st Gen MINI Cooper S Profile
Did you try connecting a battery charger, open tailgate, disconnect battery charger?
or jumper cables from another car to yours.
05MCS BEP Alta 22mm rear anti-swaybar, Madness CAI, Alta 15%, NGK BRK7EIX, M7 Strut Tower Reinforcement plates, BSH Lower Engine Mount
Old Dec 6th, 2013, 05:08 PM
Caveman - Thanks, mine was built July 02 - so I won't need to look for it
Beken -
YESTERDAY
Well, after the PSP ran and drained the battery flat, I tried to charge the battery using the under bonnet (hood?) terminals - using my old charger. The charger just stopped working. I think something has happened to the electrics. The cheap charger is now bust.
So then I tried using jump leads. As I connected the jump leads to the mini (from my Vauxhall Corsa) sparks came from the under bonnet terminals then they stopped. The mini would not start. Then when I started the engine on the Corsa - pushing a lot more juice into the jump leads, then the mini started, so my son was able to drive the mini home to our house.
Today
I bought a new top of the range charger that is (allegedly) intelligent. It incorporates a 100 amp instant start mode + a regular slow or fast charge a battery mode. However, when I connect it to the mini, it trips and I need to reset it. Something odd is happening.
The mini is now parked againt the front door - bonnet forward - of my garage so I will have to push the car into the street then I will try the jump leads again. If I can start the mini, I will immediately unlock the tailgate so I can then charge the battery.
Then later
If I can charge the battery - off vehicle - I can the install it in the mini but I dunno what will happen when I try to drive the car to a local garage to get the PSP replaced. I assume the PSP will continue to run and I guess removing the F39 fuse (which also protects the alternator - according to my Haynes manual) might stop the PSP but make steering too stiff to drive safely ?
I can maybe get a mobile mechanic (can anyone recomend one in E. London) or get a dealer to tow the mini to a garage ?
I think I'm in ScheiŖe strasse - so any tips would be appreciated.
Old Dec 6th, 2013, 07:51 PM
mab01uk's Avatar
You can drive the Mini without the power steering working but it will of course be very heavy. Any good garage should be able to swap the ps pump in a couple of hours, it is not a difficult job.....many owners have changed it diy using the various guides on the Mini forums.
It is possible to access the battery if you have no emergency cable pull by moving/forcing the rear parcel shelf so you can slide a small hand or flat hook type tool down to release the catch/lever on the folding seat back. Once you have folded one seat back down you can access the battery......however it may cause some damage to the fibre board material of the parcel shelf.
Old Dec 7th, 2013, 07:27 AM
Thank you, most helpful.
» Recent Threads
Cooper S Engine Rebuild
Yesterday 07:44 AM
Last post by marque
Yesterday 11:49 PM
1 Replies, 99 Views
Does your Mini have a name?
Mar 25th, 2014 10:00 PM
Last post by Grumpee1
Yesterday 11:29 PM
18 Replies, 1,061 Views
O2 sensors in exhaust
Yesterday 06:03 PM
Last post by marque
Yesterday 11:24 PM
1 Replies, 58 Views
Help, is this a cooper S??
Yesterday 09:29 PM
by markdm
Last post by Caveman
Yesterday 11:11 PM
5 Replies, 94 Views
Mini Cooper S R56 Timing Chain Tensioner
Feb 24th, 2013 11:53 AM
Last post by MCMULC
Yesterday 09:08 PM
9 Replies, 6,664 Views
Just bought mini what extras do I need to tell insurance about
Mar 19th, 2014 03:51 PM
Last post by JohnnyC
Yesterday 07:43 PM
7 Replies, 590 Views
should I wait or not?
Apr 14th, 2014 12:07 AM
Last post by mab01uk
Yesterday 07:10 PM
7 Replies, 422 Views
Constant problems with my R50. Should I keep it or replace? Need advice please
Apr 3rd, 2014 03:52 PM
by kteara
Yesterday 07:03 PM
14 Replies, 884 Views
Spare wheel 55 plate cooper
Yesterday 01:32 PM
by ajn
Yesterday 07:00 PM
2 Replies, 83 Views
Need new rims, any ideas
Apr 8th, 2014 10:14 PM
Last post by CoolioMcPimp
Yesterday 06:44 PM
3 Replies, 308 Views
Cup holder inserts
Yesterday 06:23 PM
Last post by Captain5691
Yesterday 06:23 PM
0 Replies, 54 Views
Electrical Issues with 2003 Cooper base
Mar 10th, 2014 07:09 PM
Last post by The Nun
Yesterday 05:29 PM
3 Replies, 445 Views
Strange Braking Noise
Jan 28th, 2014 08:27 PM
Yesterday 05:22 PM
8 Replies, 958 Views
Mini One D - engine out, how difficult?
Jan 8th, 2014 09:36 PM
Last post by scott132
Yesterday 03:19 PM
3 Replies, 691 Views
R52 A pillar interior trim removal
Yesterday 08:11 AM
Last post by clockworks
Yesterday 02:57 PM
2 Replies, 69 Views
Boot switch not working
Mar 8th, 2014 10:23 AM
Last post by burnstar
Yesterday 11:04 AM
4 Replies, 400 Views
Attention to Detail (UK) - spot the difference!
Yesterday 09:43 AM
by sailesh
Yesterday 10:47 AM
1 Replies, 121 Views
Changing Oil????
Mar 3rd, 2014 12:32 PM
Last post by habi222
Yesterday 09:31 AM
8 Replies, 739 Views
Mini Cooper S Rebuild
Yesterday 07:49 AM
Last post by budgie2014
Yesterday 07:49 AM
0 Replies, 86 Views
Engine mounts
Dec 22nd, 2013 07:47 PM
Last post by johnnycatbiscuit
Yesterday 04:21 AM
3 Replies, 800 Views
Ľ Wheel & Tire Center
