R53 15% pulley - MINI Cooper Forum
Go Back   MINI Cooper Forum > All Models & Variants > General Discussion
15% pulley on a 2005 MCS automatic is it worth it aus mini General Discussion 6 Aug 27th, 2013 03:53 PM
idler pulley question Miniblu First Generation MINI Cooper S 1 May 25th, 2013 06:00 PM
R53 JCW vs R53 S r50NI General Discussion 2 Mar 2nd, 2013 07:42 PM
Old Dec 14th, 2013, 07:41 AM
Local Time: 03:19 PM
R53 15% pulley
Thinking of buying a alta 15% supercagrger pulley. Anyone have one of these on? Or know about them? What sort of bhp does it give you? I've heard they do make a lot of difference just thought I'd see if I could get some advice.
Old Dec 14th, 2013, 07:59 AM
Also I've been told that the 17% gives more power but need an intercooler but on 1320 they are selling 11% pulleys and are saying the smaller the diameter the more power you will get. Just confused on what to buy so it's safe to run on standard intercooler
Old Dec 14th, 2013, 02:52 PM
Caveman's Avatar
Local Time: 05:19 PM
The % refers to the amount of reduction ... a 17% pulley is small than a 15% which is smaller than a 11%. As you lessen the size of the pulley you get more torque in the lower RPM range.
The JCW Engine Tuning Kit comes with about a 11% reduction pulley.
A 15% reduction pulley is probably the most common choice.
Old Dec 14th, 2013, 10:27 PM
Local Time: 04:19 PM
England
Yeah a 15% is the better option. Believe if you go higher you need other supporting mods
Old Dec 15th, 2013, 07:28 PM
Cheers guys think I'll get one ordered
Old Dec 16th, 2013, 12:31 PM
Keano's Avatar
JCW 250
United Kingdom Male View Keano's Solid Black & Body Color 1st Gen MINI Cooper S Profile View Keano's Classified Ads
This subject has been covered many many times - its the general go to first mod for the R53 and plenty of info kicking around from those who have done it...
The smaller pulley (for example a 15% pulley is 15% smaller than the stock size) will turn the supercharger faster, creating more boost and hence more torque. Fit an even smaller pulley and you will turn the supercharger even faster, generating even more boost and hence more torque... this wont continue forever though: as you turn it faster it becomes more inefficient and generates more heat. Eventually, this extra heat will start to offset the increase in boost and then the engine/ecu will 'see' the increased temps and start to reign things in to protect the engine - this is when you start to need an improved intercooler as it will cool the intake air further and help reduce the need for the engine management to cut in and help cool things down.
Generally speaking a 15% should be ok on the stock IC depending on your use of the car but it wouldn't hurt to get an uprated IC to make the most of that new boost - an uprated IC was the first mod I did to my old R53: car felt a lot better and my otherwise stock JCW 210 made 222bhp....
Running 211whp
» Recent Threads
cooper s convertible RH32
Today 08:36 AM
Last post by marque
Today 02:26 PM
1 Replies, 82 Views
2007 cooper s air filter help!!
Today 01:44 PM
by mf0017
Last post by marque
Today 01:51 PM
1 Replies, 37 Views
Death rattle - Mini One 1.4 2007
Today 09:16 AM
Last post by ozmusafir
Today 12:07 PM
2 Replies, 97 Views
High Mileage 152k miles - Mini One 04 plate
Jan 31st, 2014 09:43 AM
by raym
Today 10:45 AM
9 Replies, 1,468 Views
MOT Query
Apr 6th, 2014 04:44 PM
by lolsmit
Last post by lolsmit
Today 10:19 AM
3 Replies, 239 Views
2008 1.6 CooperD - advice?
Mar 1st, 2014 06:11 PM
by rvt50
Last post by rvt50
Today 09:39 AM
38 Replies, 2,643 Views
Alloy Wheel decision.
Jan 4th, 2014 01:41 PM
Last post by habi222
Today 08:24 AM
5 Replies, 1,037 Views
2002 Cooper electrical fault with speedo
Today 08:20 AM
Last post by legacy7770
Today 08:20 AM
0 Replies, 66 Views
Replacing Coupe SD tyres
Feb 21st, 2014 11:20 AM
Today 08:18 AM
2 Replies, 392 Views
How to Retrofit the Spacesaver Spare Wheel
Dec 6th, 2011 10:40 PM
by mab01uk
Last post by Dreadlocks
Today 08:10 AM
48 Replies, 29,720 Views
Hel Brake hose
Mar 21st, 2014 07:11 PM
Today 08:03 AM
1 Replies, 229 Views
Mini Convertible
Jan 21st, 2014 09:32 PM
Today 07:55 AM
10 Replies, 912 Views
Facelift ('05) Confusion
Yesterday 05:26 PM
by Triang
Last post by Triang
Today 04:58 AM
7 Replies, 211 Views
Trunk Handle Cover
Yesterday 02:39 AM
by iamtony
Last post by whaap
Yesterday 09:23 PM
3 Replies, 202 Views
2007 Cooper D (r56) - weird sound. Maybe clutch?
Yesterday 07:01 PM
by hyvrid
Last post by hyvrid
Yesterday 09:20 PM
2 Replies, 138 Views
2007 Cooper D (r56) - How to look after her and what to look for when buying
Apr 15th, 2014 01:10 PM
by hyvrid
Last post by hyvrid
Yesterday 08:11 PM
7 Replies, 465 Views
O2 sensors in exhaust
Apr 18th, 2014 06:03 PM
Last post by Invernessguy
Yesterday 07:22 PM
4 Replies, 281 Views
Mini One dipstick
Apr 14th, 2014 04:22 PM
by pooz23
Last post by drozd
Yesterday 07:06 PM
6 Replies, 314 Views
Facelift One ('05) Confusion...may have posted in wrong place sorry!
Yesterday 05:37 PM
by Triang
Last post by Triang
Yesterday 05:37 PM
0 Replies, 201 Views
Mini Identification
Yesterday 10:23 AM
Last post by subframe
Yesterday 05:21 PM
8 Replies, 221 Views
Wheel & Tire Center
