Wet electrics problems - MINI Cooper Forum
Go Back   MINI Cooper Forum > All Models & Variants > General Discussion
couple of problems, dash electrics and water leak asmith88 First Generation Faults & Fixes 17 Dec 20th, 2013 06:58 PM
Panoramic Sunroofs Issues, Queries, Problems etc LadyUK Second Generation MINI Cooper S 0 Nov 15th, 2013 03:43 PM
Annoying electrical problems HELP!!!! luckerww Maintenance & MINI Care 3 Oct 21st, 2012 09:56 PM
Multiple problems - linked? - D-bus? help required. KLF23 First Generation MINI Cooper 2 Oct 9th, 2012 07:04 PM
Old Dec 29th, 2013, 08:05 AM
Local Time: 02:27 AM
Carpets in my 2003 Mini Saloon got wet in local floods. All general lighting (headlamps, indicators etc) and standard installed anti-theft device etc all malfunctioning. All told that this may cause car to be written off. Question- is it practical to strip floor area and install new wiring harness? Owned car since new, full main BMW dealer service record, only 29000 miles recorded. No desire to replace it
Old Dec 29th, 2013, 09:46 AM
mab01uk's Avatar
Local Time: 03:27 AM
I would strip out the front seats (disconnect battery due to seat air bag wiring conns under seats) and carpets yourself, not a big job (many posts on here for removing front seats and carpets), beneath the carpet there is very thick (1-2 inches) soundproofing felt which acts like a sponge, remove this and dry it out plus the few wiring connectors you see, unlikely you would need a new wiring harness.
The main thing to dry out (depending on depth of flood) is the BC1 Body Control Module which could also be causing malfunctions. This is situated in the Drivers footwell and there are many posts on drying this out (see below)......if successful you won't have to replace it, it is essential the 4 large connectors plugged into it are dry (especially those low down which may have got wet) to prevent short circuits of signals to various components/modules around the 'bus' wiring network.
More Info Here:
The BC1 (Body Control Unit) - totalMINI Forums - MINI Forum
or Here:
The only reason the car would be written off is because of the time it takes to dry things out and the high hourly labour rates in main dealers, but you have nothing to loose by trying a diy solution first if you wish to keep your car.
I successfully dried out a Renault Clio for a family member over the Xmas break which was in a similar flood and would have been written off.......we borrowed a Vax water vacumn cleaner to remove the worst but with the Mini it is also essential to dry out the water retained in the thick soundproofing felt in the cavities below the carpet.
Old Dec 30th, 2013, 08:06 AM
Firstly, many thanks for your helpful reply. The flood water had reached just above the bottom edge of the doors before I moved the car manually to dry ground. When I got into the car the was little evidence of water other than the damp carpet. I guess the soundproofing would have absorbed it all?
Secondly, had to move the car rearwards up a slope which meant the front of the car very briefly dipped into the flood water (just above bumper). I think I should check the oil as there would have been water in the exhaust which may have run forwards (downhill), though is no sign of contamination on the dipstick.
Old Dec 30th, 2013, 08:37 AM
It's very unlikely for water to get into the engine from the exhaust. If the engine was running, the exhaust gasses would have blown any water out and anyway the exhaust ports (connecting the exhaust to the engine) are fairly high up.
In any case, if the engine runs, no water has got in. I believe if you try to start an engine with water in the cylinders, it won't turn over, as the water isn't compressible, so the engine will stop with a clunk before it gets started.
Old Dec 30th, 2013, 07:47 PM
mab01uk's Avatar
If flood water is drawn into an engine through a low down air intake it locks solid and is usually a write-off......so your mini should be fine if it runs ok......once you have dried it out inside.
I would make sure the two lower BC1 wiring connectors near the driver floor in footwell are completely dried out and any wiring connectors under the floor soundproofing.
Tags: ,
» Recent Threads
Help, is this a cooper S??
Yesterday 09:29 PM
by markdm
Last post by markdm
Today 01:29 AM
6 Replies, 109 Views
Cooper S Engine Rebuild
Yesterday 07:44 AM
Last post by marque
Yesterday 11:49 PM
1 Replies, 105 Views
Does your Mini have a name?
Mar 25th, 2014 10:00 PM
Last post by Grumpee1
Yesterday 11:29 PM
18 Replies, 1,066 Views
O2 sensors in exhaust
Yesterday 06:03 PM
Last post by marque
Yesterday 11:24 PM
1 Replies, 64 Views
Mini Cooper S R56 Timing Chain Tensioner
Feb 24th, 2013 11:53 AM
Last post by MCMULC
Yesterday 09:08 PM
9 Replies, 6,667 Views
Just bought mini what extras do I need to tell insurance about
Mar 19th, 2014 03:51 PM
Last post by JohnnyC
Yesterday 07:43 PM
7 Replies, 599 Views
should I wait or not?
Apr 14th, 2014 12:07 AM
Last post by mab01uk
Yesterday 07:10 PM
7 Replies, 426 Views
Constant problems with my R50. Should I keep it or replace? Need advice please
Apr 3rd, 2014 03:52 PM
by kteara
Yesterday 07:03 PM
14 Replies, 890 Views
Spare wheel 55 plate cooper
Yesterday 01:32 PM
by ajn
Yesterday 07:00 PM
2 Replies, 84 Views
Need new rims, any ideas
Apr 8th, 2014 10:14 PM
Last post by CoolioMcPimp
Yesterday 06:44 PM
3 Replies, 308 Views
Cup holder inserts
Yesterday 06:23 PM
Last post by Captain5691
Yesterday 06:23 PM
0 Replies, 57 Views
Electrical Issues with 2003 Cooper base
Mar 10th, 2014 07:09 PM
Last post by The Nun
Yesterday 05:29 PM
3 Replies, 447 Views
Strange Braking Noise
Jan 28th, 2014 08:27 PM
Yesterday 05:22 PM
8 Replies, 961 Views
Mini One D - engine out, how difficult?
Jan 8th, 2014 09:36 PM
Last post by scott132
Yesterday 03:19 PM
3 Replies, 697 Views
R52 A pillar interior trim removal
Yesterday 08:11 AM
Last post by clockworks
Yesterday 02:57 PM
2 Replies, 75 Views
Boot switch not working
Mar 8th, 2014 10:23 AM
Last post by burnstar
Yesterday 11:04 AM
4 Replies, 402 Views
Attention to Detail (UK) - spot the difference!
Yesterday 09:43 AM
by sailesh
Yesterday 10:47 AM
1 Replies, 125 Views
Changing Oil????
Mar 3rd, 2014 12:32 PM
Last post by habi222
Yesterday 09:31 AM
8 Replies, 742 Views
Mini Cooper S Rebuild
Yesterday 07:49 AM
Last post by budgie2014
Yesterday 07:49 AM
0 Replies, 87 Views
Engine mounts
Dec 22nd, 2013 07:47 PM
Last post by johnnycatbiscuit
Yesterday 04:21 AM
3 Replies, 801 Views
Wheel & Tire Center
