Cooper S turbo blow into water jacket - MINI Cooper Forum
post #1 of 1 (permalink) Old Jan 7th, 2014, 09:29 AM Thread Starter
Local Time: 03:14 PM
South Africa
South Africa Cooper S turbo blow into water jacket
My 2008 Cooper S seriously overheated, I have replaced all the damaged parts, she runs very well and idles perfectly. However under load (I assume when the turbo comes in) the filler tank cap sprays out steam. I suspect that the cylinder head gasket is damaged or the cylinder head may be cracked.
My question is should this not be evident even when idling?
If I remove the cylinder head, could it be warped from the overheating? How can I confirm this without removing it?
Any advise would be greatly appreciated.
Fats is offline
Forge Uprated Alloy Intercooler for Mini Cooper S Turbo fcminicoopers Second Generation MINI Tuning 4 Mar 25th, 2013 03:44 PM
Mini Cooper S Turbo air inlet JGrimshaw Second Generation Faults & Fixes 2 Mar 1st, 2013 12:14 AM
Forge - Blow Off Adaptor For BMW Mini Cooper S Turbo UtilityGuy Second Generation MINI Tuning 1 Jan 21st, 2013 08:17 AM
2008 R56 Mini Cooper S Turbo! RGJACOBSON Welcome New Members 0 Dec 26th, 2012 01:48 AM
2003 Cooper using water minioll First Generation MINI Cooper 2 Nov 1st, 2012 01:23 PM
