Re map ecu - MINI Cooper Forum
post #1 of 5 (permalink) Old Jan 7th, 2014, 12:47 PM Thread Starter
Local Time: 02:52 PM
Cyprus
Talking Re map ecu
Hello every one, i m new to mini cooper. i just bought a mini cooper s r53 year of build 2004 with 45000 kh on the clock and allready start the mods... i put a kavs 15% pulley and thinking of changing the fuel injectors as well. i notice that a remap of ecu is nesecary for that mod... can you please tell me more on this section please like how i do the remap is it really nesecary and all i have to now.
is there any other mod to do after i change the sc pulley?
the injectors that i found is bosch 550
ps sorry for my engilish...
petros88 is offline
post #2 of 5 (permalink) Old Jan 7th, 2014, 12:55 PM
JCW 250
Keano's Avatar
Local Time: 03:52 PM
United Kingdom Male View Keano's Solid Black & Body Color 1st Gen MINI Cooper S Profile View Keano's Classified Ads
If you go with larger injectors you will need to map for it otherwise you will be putting in too much fuel (the car will think it still has 330cc afterall) so the map needs to be done to scale the injectors appropriately.
Personally, I would leave the injectors until further along your modding journey - do you have any other mods besides the pulley? if not, you can add a dave.f air intake, exhaust manifold (JCM / Janspeed etc), intercooler perhaps a new cat back... I would try to work it so that you can fit a new camshaft at the same time as the bigger injectors and then tune for the job lot
RMW in the states can do remote tuning, not sure if lohen or P-Torque can do this or not.
In summary and IMO - leave the injectors for now and fit the above mods instead. If you can get a set of JCW injectors you could get a JCW map flash to keep you going (not sure how great a solution this is tbh) but if you have bigger plans I would wait and do it a little further down the line.
Running 211whp
Keano is offline
post #3 of 5 (permalink) Old Jan 7th, 2014, 02:58 PM Thread Starter
Cyprus
thank you very much for your help... i have one more question. in the morning or the if i have the car parked for many hours and start it i hear a tikking noise is the hydraulic valves till the oil goes up?
petros88 is offline
post #4 of 5 (permalink) Old Jan 7th, 2014, 04:33 PM
JCW 250
Keano's Avatar
The injectors can be noisy and will tick but if its only on first start and goes after a little while then yes I would say it could be your hydraulic lifters.
Had mine change - does it sound like mine in my video?
Running 211whp
Keano is offline
post #5 of 5 (permalink) Old Jan 10th, 2014, 05:21 AM Thread Starter
Cyprus
Hello mate no is not like that is a very slide ticking noise and is going away as soon as the engine warm up
petros88 is offline
2011 Cooper D / Poor idling after new ecu Mushy007 Second Generation Faults & Fixes 2 Jan 6th, 2014 07:01 PM
HCW little black box behind ECU? RachyS First Generation MINI Cooper S 3 Mar 18th, 2013 03:28 PM
Navigation - Map & Display questions npound Second Generation Interior & Ice 2 Dec 6th, 2012 10:53 AM
Map or maf sensor morgi27 Maintenance & MINI Care 5 Oct 7th, 2012 03:49 PM
