help: Passenger window doesn't slide back up when closing door - MINI Cooper Forum
post #1 of 2 (permalink) Old Jan 14th, 2014, 09:17 PM Thread Starter
Local Time: 01:27 PM
Hi, I'm new to this forum.
My 2011 Mini Cooper S's passenger side window slides down slightly when opening the door as it should, but when closing the door, it never slides back up to seal. As a result, the passenger door must be closed, the window needs to be closed by the driver via the switch and then close the drivers side door.
Any idea why this is? The drivers side works fine, but I would have expected if the passenger window doesn't close on its own then it wouldn't open on its own, but clearly that's not the case...
Any ideas...?? Thanks.
Niral is offline
post #2 of 2 (permalink) Old Jan 14th, 2014, 10:06 PM
mab01uk's Avatar
Quoted: 1 Post(s)
On older Mini's you can reset the windows by holding the switch in the up position for 30 seconds with ignition switched on.
mab01uk is offline
Unable to operate Driver's window if passenger door open TheGadgetMan Second Generation Interior & Ice 1 Jun 5th, 2013 08:45 AM
Passenger door doesn't open from inside... Richardestys Second Generation Faults & Fixes 0 Apr 1st, 2013 08:20 PM
Passenger Door Won't Open wildmind_uk First Generation Faults & Fixes 1 Jan 24th, 2013 03:42 PM
Mini one door won't close and window sticking out wolverhamptonminione Second Generation Faults & Fixes 2 Jan 18th, 2013 07:51 AM
