Mini Cooper S Convertible - recall info - MINI Cooper Forum
post #1 of 4 (permalink) Old Jan 20th, 2014, 04:34 PM Thread Starter
Local Time: 07:59 PM
DIY Mini Cooper S Convertible - recall info
Hi.
I am looking for some advice about my 09 Cooper S convertible. The engine warning light has been on and off for a few weeks. Mini have had a look today and following a 150 diagnostics charge have advised that there is a build up of sludge due to lots of short journeys, meaning the car doesn't get hot enough to burn this off. I apparently need a new rocker cover amongst other things. The estimated cost is between 800 + 1500, depending on how much damage has been done. Mini have offered to cover the cost of the parts, which has made me suspicious that this may be a common fault or possibly a recall.
The car has done just over 40,000 miles. Does anyone have any advice?
Many thanks
Jen
92walsonway is offline
post #2 of 4 (permalink) Old Jan 20th, 2014, 04:48 PM
Caveman's Avatar
Local Time: 09:59 PM
Quoted: 83 Post(s)
It's a common problem with the N14 engine.
For more info Google "mini cooper engine coking (or carbon buildup)".
Caveman is offline
post #3 of 4 (permalink) Old Jan 21st, 2014, 03:01 PM
Local Time: 08:59 PM
To be honest its a common problem with all cars, I don't know about a specific fault with this engine.
you should always give a car a long run now and again to warm up to then clear it out, especially if its subject to a lot of short journeys.
Also with a lot of short journeys the car ideally needs closer services and the fuel used will play a part in the carbon build up as well, so if you don't use say bp ultimate (which contains cleaning additives) you will need to run a fuel system cleaner through it periodically so the engine burns cleaner again.
markwazere is offline
post #4 of 4 (permalink) Old Jan 21st, 2014, 04:14 PM
Caveman's Avatar
Quoted: 83 Post(s)
The N14 engine is direct injection, so fuel doesn't clean the intake valves ... and that's where the carbon builds up.
Also, the PCV set up isn't the best design ... which is why some owners are fitting oil catch cans.
Caveman is offline
Tags: , ,
2014 MINI Cooper Hardtop Revealed AutoGuide.com MINI News 15 Apr 23rd, 2015 04:15 PM
Newbie - Mini Cooper Convertible owner Moo1892 Welcome New Members 0 Sep 17th, 2013 07:34 PM
Mini Cooper S Convertible - What's it worth? soundboy10 General Discussion 0 Feb 11th, 2013 01:00 PM
Mini Cooper S Convertible Auto Transmission Fault dudexk First Generation Faults & Fixes 0 Nov 8th, 2012 10:57 AM
