advice/help needed please - MINI Cooper Forum
post #1 of 3 (permalink) Old Jan 26th, 2014, 04:46 PM Thread Starter
Local Time: 03:47 PM
DIY advice/help needed please
Good Afternoon,
I purchased have a 2009 mini convertible.Unfortunately the roof at the rear back quarter behind the driver seat is not tight and it appears the plastic tensioner is broken. Allowing water ingress. The roof works perfectly well other than this.Can any one please advise were to get this fixed or indeed can it be fixed. I am based in Yorkshire but would travel .
Thanks David
mini mirfield is offline
post #2 of 3 (permalink) Old Jan 26th, 2014, 05:38 PM
Local Time: 08:47 AM
Quoted: 16 Post(s)
United States Male
Hello and welcome to our forum. I don't have an exact answer for you but I would start off by calling a Mini dealership. I would think they should be able to order it for you. If they can't help you I'd give any trim (upholstery) shop a call and see if they could fabricate what you need.
whaap is offline
post #3 of 3 (permalink) Old Feb 1st, 2014, 06:53 PM Thread Starter
update
Thanks for your advice. I have got the problem sorted now.A company in Leeds called Mad4Mini took the time and effort to fix this for me .I cannot recommend them highly enough. Thanks to them it is now good as new. Mad4mini brilliant.
Help needed with brakes / servicing saisai1 Wheels, Tyres & Brakes 3 Jan 15th, 2014 04:07 PM
Audio Issues - Help needed! hi_22 Second Generation Interior & Ice 0 Sep 18th, 2013 05:52 PM
Advice/help needed. Mini cooper - Chrome filler cap. Poor Service. What would you do? digitaluk Second Generation MINI Exterior 5 Mar 22nd, 2013 12:28 PM
Mini Cooper S, slight oil leak, helped needed! Lainchers First Generation Faults & Fixes 6 Feb 23rd, 2013 10:24 PM
