Immobiliser - MINI Cooper Forum
post #1 of 7 (permalink) Old Feb 1st, 2014, 11:13 AM Thread Starter
Local Time: 05:50 PM
Immobiliser
Sorry if this in the in the place. I wasn't sure where to put it.
Part of the plastic on my key fell off awhile back but i was still able to remote open the car door. Yesterday it failed to open remotely for the first time so i manually had to open the car door but to my surprise the engine wouldn't start.
I now know this is due to the immobiliser. I didn't even know i had one or what it was before yesterday. I've had to leave my car at work and was planning to get it over the weekend as i have a spare key at home.
Will this spare key work or has me trying to start it with the broken key permanently locked it and i'll need a locksmith or someone to sort it out? I assume this isn't the case but wanted to double check.
phatus is offline
post #2 of 7 (permalink) Old Feb 1st, 2014, 05:12 PM
mab01uk's Avatar
Quoted: 1 Post(s)
If the spare key is a remote key with good battery it should be fine.
All cars have had to have engine imobilisors fitted for some years now in the UK.
When your other key broke did the immobilizer part fall out?
What year is your Mini?
See photos here:
"Here is the key with the circuit board removed. You can see the immobilizer in the back cover; here is how to gently pry it out. It's a sealed unit and you probably won't hurt it but be gentle anyway. Put it in a safe place as well- you DO NOT want to lose this."
http://www.mini2.com/forum/first-gen...air-guide.html
mab01uk is offline
post #3 of 7 (permalink) Old Feb 1st, 2014, 06:27 PM Thread Starter
Thanks for the reply.
No the immobilizer part didn't fall out. It was only part of the plastic that covered the circuit board underneath. The first picture in the link you posted shows the key missing two parts of plastic. My key is missing the section on the left of this picture. It covers the button which remotely opens the car door.
I just assumed the circuit board had become faulty due to it being exposed. Could it be that i need to replace the battery within the key to get it working again?
The mini is year 2004.
phatus is offline
post #4 of 7 (permalink) Old Feb 2nd, 2014, 12:05 PM
mab01uk's Avatar
Quoted: 1 Post(s)
If the circuit board is exposed the tiny microswitches below the outer buttons often fail soon afterwards.
If you want to avoid buying a new remote key from BMW (approx. 150 with proof of ownership) you could try here:
2001-2004 MINI Clamshell Key Repair Service - Mini Cooper Register Forum
mab01uk is offline
post #5 of 7 (permalink) Old Aug 21st, 2016, 07:48 AM
Quoted: 1 Post(s)
You don't have to go to a dealer. There are 2 ways to get a transponder key to work on a Honda. You can program the immobilizer to accept the new key OR you can clone the new key to the same code as an existing key. But you must at the very least have a handheld immobilizer key programmer. That means a well equipped Locksmith will be able to cut and program a key OR a dealer
alexanderwhite is offline
post #6 of 7 (permalink) Old Aug 21st, 2016, 07:43 PM
Moderator
minione2002's Avatar
Quoted: 438 Post(s)
A Honda? I think your on the wrong site M8
Sent from my GT-N7100 using Tapatalk
minione2002 is offline
post #7 of 7 (permalink) Old Aug 21st, 2016, 07:51 PM
Quoted: 747 Post(s)
Pmsl back to the infamous "locksmith" pish again. Typical spammer!
Sent from my SM-G920F using Tapatalk
SeanC is online now
Another Immobiliser problem. AussieJoe First Generation Faults & Fixes 2 Apr 8th, 2013 03:07 AM
