Help PLEASE - MINI Cooper Forum
post #1 of 7 (permalink) Old Feb 9th, 2014, 02:18 PM Thread Starter
Local Time: 11:20 PM
Help PLEASE
I just had my 09 mini Cooper painted.Now my windows roll down and sunroofs tilt up when I take key fob out of ignition and close either door.Any advice greatly appreciated.
Millie09 is offline
post #2 of 7 (permalink) Old Feb 10th, 2014, 10:03 AM
Local Time: 04:20 AM
Quoted: 2 Post(s)
United Kingdom View AMAUTOS7's Classified Ads
As you said the car was painted
The rubber seal on the windows might have not been put back right causing them to roll back
AMAUTOS7 is offline
post #3 of 7 (permalink) Old Feb 11th, 2014, 12:57 PM
heathwebbo's Avatar
Your problem will most likely be the drivers door lock mechanism, they have micro switches in them. On most minis if you put your key in the door lock & hold it in the unlock position the windows will go down & sunroof open (sometimes works holding unlock button on remote) I would suggest either the painters have put the lock back wrong in someway (if they removed it) or the microswitches have gone bad. The best way to test this is to remove the interior door panel & unplug the electrics to your door lock. This should stop your problem for now until you can get the lock replaced. You can still lock the car with your key but you will lose the remote locking/unlocking until the mechanism has been replaced
Let us know how you get on
heathwebbo is offline
post #4 of 7 (permalink) Old Feb 11th, 2014, 05:38 PM Thread Starter
Thanks;will try and let you know
Millie09 is offline
post #5 of 7 (permalink) Old Feb 12th, 2014, 11:43 PM Thread Starter
Smile
Thank you sooo much. It was the pin going into lock mechanism in a bind. Don't. Have to go to dealer now. Thank you again
Millie09 is offline
post #6 of 7 (permalink) Old Feb 13th, 2014, 10:12 AM
heathwebbo's Avatar
Glad you got it fixed
post #7 of 7 (permalink) Old Feb 16th, 2014, 04:30 PM
...opinionated!
Deep_27a's Avatar
Local Time: 05:20 AM
United Kingdom Male View Deep_27a's  &  2nd Gen  Profile View Deep_27a's Classified Ads
Great fix suggestion Heath! I would never have thought of that one personally!
Deep_27a is offline
