Oil pressure in Mini S 2006 - MINI Cooper Forum
post #1 of 10 (permalink) Old Feb 10th, 2014, 12:20 PM Thread Starter
Local Time: 02:06 AM
Argentina
Hi all!
I have a problem in my Mini. My car have 41000 km (or 25500 mile), when I purchase the car had no problem.
After 500 km I made a general service (change oil, filters, etc). Since this moment, when started the engine (in the morning, when the engine is cold) I don't have problem with the pressure (My Mini have the sport chrono), immediately set on 1 BAR. But, in some case, when the engine is hot ( 90 C or 194 F) the pressure not give up until small accelerated, since this moment the pressure is always kept well, and never drops while the engine is turned on.
What think you about my problem? What can it be?
Thanks for your support!
Marcelo.
marceloicardo is offline
post #2 of 10 (permalink) Old Feb 10th, 2014, 06:09 PM
Local Time: 05:06 AM
Hi ya
If the car was ok before the service the only thing I can think of is that you may have a bad oil filter
Some aftermarket (non bmw) oil filters can cause bad oil pressure and oil flow, if you have not used a original bmw mini filter I would say start there it is a known problem.
Hope this helps
marque is offline
post #3 of 10 (permalink) Old Feb 11th, 2014, 11:45 AM
I had exactly the same only last week. Low oil pressure light came on at tickover when the mini had warmed up. The correct BMW filter solved it.
dave123 is offline
post #4 of 10 (permalink) Old Feb 11th, 2014, 06:58 PM Thread Starter
Argentina
Thanks to both for your help! I'll change the filter this wkend!
post #5 of 10 (permalink) Old Feb 11th, 2014, 07:11 PM Thread Starter
Argentina
What is the brand of the OEM filter?
post #6 of 10 (permalink) Old Feb 11th, 2014, 08:01 PM
Dermottdog's Avatar
2006, is that 2nd gen Mini. Purflux make the 2nd gen OEM oil filters
Dermottdog is offline
post #7 of 10 (permalink) Old Feb 11th, 2014, 08:06 PM
Caveman's Avatar
Local Time: 07:06 AM
Quoted: 90 Post(s)
1st Gen Hatchbacks were produced through the end of November 2006.
Caveman is offline
post #8 of 10 (permalink) Old Feb 12th, 2014, 11:06 AM Thread Starter
Argentina
My Mini is of November 2006, 1st gen. Is purflux the OEM oil filter? Thanks again!
post #9 of 10 (permalink) Old Feb 12th, 2014, 02:03 PM
Couran's Avatar
Australia
I already changed the oil filter the day I got the oil change and the check engine light still wont go off after replacing the oil sensor and oil pump. Whats the next option I have.
Couran is offline
post #10 of 10 (permalink) Old Feb 12th, 2014, 02:55 PM Thread Starter
Argentina
Couran, do you have my same problem? When did start your problem?
MCS Engine noise when cold CBCooper Second Generation Faults & Fixes 2349 Mar 30th, 2016 09:09 PM
2006 Mini Cooper S, oil leak UKGray First Generation MINI Cooper 6 Jan 19th, 2014 10:01 PM
Low Oil Pressure - Filter Debris in Oil System??!! MissMac General Discussion 5 Apr 1st, 2013 10:23 AM
2006 Cooper R50: Oil and Tire Pressure rphox2003 First Generation MINI Tuning 3 Mar 16th, 2013 02:46 PM
Mini Australia service chilld Dealership Feedback 4 Sep 4th, 2012 05:29 AM
