Fuel cap lock on mini cooper s - MINI Cooper Forum
post #1 of 2 (permalink) Old Feb 16th, 2014, 04:18 PM Thread Starter
Local Time: 12:05 PM
England
I wonder if anyone can help,have just purchased a mini cooper s,but noticed the chrome fuel cap does not lock when car locked,looks like a little solenoid in there,is this a common thing is it easy to replace.
Thanks for any help or advice.
Coops253 is offline
post #2 of 2 (permalink) Old Feb 16th, 2014, 06:11 PM
heathwebbo's Avatar
They are quite easy to replace the easiest way is to remove the back light you can also see what your doing a lot better. It might be worth taking it off & having a look at it first as its just a little electric motor connected to a thin metal rod & plastic plunger, something might be disconnected/stuck somewhere. To get to the plunger which pushes through the fuel cap you have to put your arm through the back light right through the rear wing to reach it which is a bit fiddly. If you open your fuel flap you can see the little plunger, try locking the car with the flap open to see if it moves
heathwebbo is offline
2014 MINI Cooper Hardtop Revealed AutoGuide.com MINI News 15 Apr 23rd, 2015 03:15 PM
high pressure fuel pump leak and head office lies! Shanos General Discussion 0 Nov 29th, 2013 04:24 PM
Advice/help needed. Mini cooper - Chrome filler cap. Poor Service. What would you do? digitaluk Second Generation MINI Exterior 5 Mar 22nd, 2013 12:28 PM
How to change a Mini Cooper S centre cap Lawrence1584 General Discussion 3 Nov 16th, 2012 04:52 PM
2001 Mini Cooper - Lost petrol cap caffelatte1 First Generation MINI Exterior 5 Nov 4th, 2012 09:08 AM
