Starter won't engage..... Help!!! - MINI Cooper Forum
post #1 of 4 (permalink) Old Feb 16th, 2014, 04:22 PM Thread Starter
Local Time: 12:11 AM
Canada
I bought a 2003 Mini for my GF to drive when she's up here in the great white north. The previous owner stated it had a bad starter. With the key in the ignition and turned to start (or on) everything works, but the car would not turn over. The car does chime/ding when the key is held near the ignition. I noticed that the key will not lock or unlock the doors but the back hatch does lock and unlock off the key and the park lights light up when the button on the key is pressed. If I hold the button down for a couple of seconds both windows roll down.
I replaced the starter yesterday and upon trying to start the car....nothing. I still had the heat shield off of the starter so I jumped the solenoid to the starter with the key on. The car fired immediately and ran/drove great...... with the exception of a thump in the passenger CV joint (that will be a separate thread....). I reset the ECU and that made no difference. Still no starter engagement. I also have no codes stored in the computer.
Any advice/comments would be appreciated. I don't think my GF will enjoy reaching around a hot exhaust to install the starter jumper.
Thanks in advance.
Allan
Al T is offline
post #2 of 4 (permalink) Old Feb 16th, 2014, 05:32 PM Thread Starter
Canada
I'm thinking maybe it's the clutch switch? Is there an easy way of bypassing this to check it? I'm assuming this is it?
Thanks in advance.
Allan
Al T is offline
post #3 of 4 (permalink) Old Feb 16th, 2014, 10:33 PM
mab01uk's Avatar
Local Time: 06:11 AM
Quoted: 1 Post(s)
If no luck on here try NAM forum in USA:
Stock Problems/Issues - North American Motoring
mab01uk is offline
post #4 of 4 (permalink) Old Mar 11th, 2014, 05:39 PM Thread Starter
Canada
Bit of an update for those with similar issues. It turned out to be a bad clutch sensor. The starter was probably OK all along...... but at least now I have a new starter as well.
Al T is offline
Gear Lever Gate Fails to Engage Shaunf General Discussion 1 Sep 15th, 2015 05:03 AM
mini 2010 starter push button stuck in fern Second Generation Faults & Fixes 1 Jan 12th, 2014 10:20 PM
Non starter Earnest Lee Second Generation Faults & Fixes 0 Jan 2nd, 2014 04:41 PM
2002 Cooper S - Starter issues? WhyBry First Generation Faults & Fixes 0 Dec 28th, 2013 10:32 PM
Remote Car Starter Joelyn General Discussion 4 Nov 1st, 2012 10:10 AM
