Newbie with Engine Problems - MINI Cooper Forum
post #1 of 1 (permalink) Old Feb 19th, 2014, 11:32 AM Thread Starter
Local Time: 05:02 PM
Mauritius
Hi All
I am new to the forum and desparately need advice.
I have a 2007 Cooper S, recently started having problems where the car felt very juddery not a smooth drive at all and on start up from cold was a problem. Its starts perfectly but then the revs drop and the car just stalls, its takes between 5-10 attempts to get the car to do anything.
My mechanic has cleaned the manifest, replaced coils and replacing the fuel pump has fixed the juddering but its still having the same problem starting from cold.
Please can anyone help, has anyone had the same issue????
emmaplu is offline
2009 Cooper D Engine Problems (Turbo Lag) Bozzer Second Generation Faults & Fixes 92 Nov 14th, 2015 09:04 AM
Engine power problems S works Asif jcw First Generation MINI Cooper S 10 Oct 27th, 2013 10:36 PM
Possible problems from engine overheating.... Freddiecider Second Generation Faults & Fixes 4 Apr 28th, 2013 11:04 PM
Cracked engine block? Help please?! rhutch First Generation MINI Cooper 2 Dec 16th, 2012 11:24 PM
BMW three-cylinder MINI engine revealed mab01uk MINI in the Media 1 Oct 9th, 2012 11:42 PM
