HELP please!!! R56 steering issues - MINI Cooper Forum
post #1 of 3 (permalink) Old Feb 21st, 2014, 04:19 PM Thread Starter
Local Time: 10:13 AM
Basically i clipped a curb with my passengers side front wheel at low speeds , no serious cosmetic damage to the wheels , just the same wheel is majorly out with tracking and my power steering is completely off , i have taken the wheel off and cannot see any damage , there is no play in it what so ever , the amber light with a steering wheel and an exclamation mark came up on my dash also , as i said the only thing i can see is the left side wheel is slightly to the left , iv booked in for tracking and tires tomorrow but would like to have some sort of idea what is wrong before hand .
All help appreciated thanks.
Josh
joshdaniel36 is offline
post #2 of 3 (permalink) Old Feb 21st, 2014, 04:37 PM
Local Time: 09:13 AM
Hi ya
it sounds like you need the tracking and geometry checked, get the steering angle sensor re calibrated/checked if possible.
but TBH it does sound like you have bent something or damaged the steering rack :-( hopefully not.
you could try the disconnect the battery leave it for 30 min trick see if the fault clears. but if its stored a code it will need to be cleared
but i think you are going to need a trip to the stealers :-(
hope this helps
marque is offline
post #3 of 3 (permalink) Old Feb 21st, 2014, 04:39 PM Thread Starter
thanks marque! will get back to you tomorrow , fingers crossed
Will r56 steering wheel fit r53? Mattiaas First Generation Interior & Ice 1 Jan 12th, 2014 05:12 PM
R56 Overload indicator light, no water in engine issues LadyUK Second Generation Faults & Fixes 1 Nov 13th, 2013 06:26 PM
MINI 2006 1.6 power steering issues garethbeardsworth First Generation Faults & Fixes 2 Apr 2nd, 2013 02:23 PM
Taking apart R56 JCW steering Wheel bodovg General Discussion 1 Mar 22nd, 2013 06:51 PM
MCS R56 power issues Foreteewinks Second Generation Faults & Fixes 3 Mar 8th, 2013 03:17 PM
