Ignition Key cutting <SOLVED> - MINI Cooper Forum
post #1 of 6 (permalink) Old Feb 28th, 2014, 02:50 PM Thread Starter
Local Time: 07:09 AM
Thumbs up Ignition Key cutting <SOLVED>
I have an R50 2001 Cooper.
I noticed the other day that the remote fob on the key has worn through and there is a hole... so I bought a replacement key from an auction site which came with no electronics and a blank key blade which can be cut.
I wrongly thought that the old blade could be removed and fitted to the new fob (which I have done in the past on other cars)... but its fixed and cant be removed.
As I have the electronics I rang the local BMW garage to see if they could cut the blade and the guy told me that they have to send it away and the charge would be about 120 as it needs coding to the vehicle.
Does anyone know if the key blade is chipped in some way which needs registering to the car - or is he thinking that I have a key with new fob which needs coding?
If he is getting confused - does anyone know where I can get the blank key blade cut to work in my car?
I am in Kent/East Sussex area BTW.
SlipMat is offline
post #2 of 6 (permalink) Old Feb 28th, 2014, 05:07 PM
hi
if its just a new case and blade then it wont be possable to have it coded the idea of a new case is to swop the insides of your old key to the new case then have your new blade cut at any locksmith to match your old key
your key will then work as it did on the car
kelv1962 is offline
post #3 of 6 (permalink) Old Mar 2nd, 2014, 09:11 AM Thread Starter
OK - I had the new blade cut and it fits and turns on... all the dash lights come on - but when you turn the key to start, nothing happens! It is as though the engine is immobilised.
If I out the original key in and start the car - then turn it of and remove the original key and put the new one in, it starts OK - then when you stop driving and turn it off, then try and start it again with the new key still in the ignition - nothing happen.
You have to start it with the original then switch the keys over.
Any ideas?? I dont want to move the remote electronics from the old key to the new one if it wont work... or will moving the electronics cure it??
I cant see that the blade is chipped in any way - so cant work out why it wont start :-(
SlipMat is offline
post #4 of 6 (permalink) Old Mar 2nd, 2014, 10:00 AM
Local Time: 05:09 PM
Quoted: 3 Post(s)
Australia Male
Garage
The original key has your imobilser chip in it, you will need to cut the Fob open on both keys and transfer the chip.
burnstar is offline
post #5 of 6 (permalink) Old Mar 2nd, 2014, 11:00 AM Thread Starter
Thanks Burnstar
Is the chip actually in the fob plastic or is it part of the unlocking circuit, so when I move the circuit over it will start working?
SlipMat is offline
post #6 of 6 (permalink) Old Mar 2nd, 2014, 03:19 PM Thread Starter
Ok now I have actually opened the fob its obvious.
The new fob had the cut-out for the chip... so moved it over and now it works fine.
SlipMat is offline
Key fob not unlocking/locking doors but also starting car Petehuws First Generation Faults & Fixes 2 Mar 10th, 2017 02:30 PM
Where to get a spare key for R50/R52 in Sydney/OZ? simonjo Australia 14 Aug 6th, 2016 09:30 AM
First generation clamshell key repair guide Valvashon First Generation Faults & Fixes 2 Jul 26th, 2016 10:48 AM
Replacement key justinhi General Discussion 1 Mar 5th, 2013 10:14 PM
Replacement Remote Key conan7772 First Generation Faults & Fixes 7 Jan 13th, 2013 03:49 AM
