Road Noise - MINI Cooper Forum
post #1 of 4 (permalink) Old Feb 28th, 2014, 07:02 PM Thread Starter
Local Time: 04:35 PM
Road Noise
I have a R53 Cooper S JCW that i recently bought. Knowing the car and the characteristics i have mistaken the road noise thinking it was normal...
In a straight line the road noise is very loud, however when i go road a left hand bend the noise stops, I'm not going at high speed this is anything from 30mph. this doesn't seem to happen on a right bend.
Is there an underlying problem, bearing, bush, steering etc...?
any advice is welcomed....
masterhalifax is offline
post #2 of 4 (permalink) Old Feb 28th, 2014, 07:46 PM
heathwebbo's Avatar
Sounds most likely like a wheel bearing. Jack each wheel up & spin it by hand & you will most likely be able to hear which one it is & maybe able to feel play in it
heathwebbo is offline
post #3 of 4 (permalink) Old Feb 28th, 2014, 08:21 PM Thread Starter
Good Point....
Will get it jacked up in the morning and have a feel. I presume they should spin pretty freely and quiet?
post #4 of 4 (permalink) Old Feb 28th, 2014, 10:36 PM
mab01uk's Avatar
Quoted: 2 Post(s)
I would agree, most likely a noisy wheel bearing.......sometimes they drone/whirr in a straight line but the noise stops when bearing load is increased or reduced during cornering on one side or the other.
mab01uk is offline
2006 1.4 Mini One D Idle Knocking Noise Just purchased. quemlar007 First Generation MINI One D 1 Sep 30th, 2014 01:46 PM
Redwoods Road Trip 2014 m3dragon Northern California Region 5 May 8th, 2014 03:27 AM
Wits End with this Noise - Please Help! Vicki29 Second Generation Faults & Fixes 12 Dec 29th, 2013 10:35 AM
Noise, Noise, Noise Teddy Boy General Discussion 19 Nov 7th, 2012 01:02 PM
Weird Noise between 50-79MPH Laura452 First Generation Faults & Fixes 5 Oct 30th, 2012 09:17 PM
