Hydrauilc engine mount (driver side) - MINI Cooper Forum
post #1 of 6 (permalink) Old Mar 4th, 2014, 01:20 PM Thread Starter
Local Time: 06:10 AM
Cyprus
Hello to all i install about a month ago h&r springs (red one) they are excelent not much different from stock but the problem is:after i install them the hudrauilic engine mount explode,i put a new one and after 20 days the new explode again. can anyone explain me this please ?
Regards Petros
petros88 is offline
post #2 of 6 (permalink) Old Mar 4th, 2014, 10:21 PM
mab01uk's Avatar
Quoted: 1 Post(s)
Never heard of that happening before......the ride will be harsher on your new springs but should not affect the engine mounts....
mab01uk is offline
post #3 of 6 (permalink) Old Mar 5th, 2014, 05:42 AM Thread Starter
Cyprus
thank you very much for your answer. i took my mini in order to change the moun again. i ll post if i find the problem
petros88 is offline
post #4 of 6 (permalink) Old Mar 5th, 2014, 10:15 AM
Hi ya
You could have just been un lucky, I take it your not jacking the car up on the sump case, people my laugh but I have seen it.
Before fitting your new mount, I would check the condition of other mounts,
Just Incase they are worn and causing it to overload the hyd engine mount causing it to fail.
Personally I would buy a vibra tec engine mount I run a full set on mine there much better.
http://orranje.co.uk/shop-by-brand/v...-engine-mount2
When you fit the new mount make shore there is no side loading on it and it sits in its natural position
Hope this helps
marque is offline
post #5 of 6 (permalink) Old Mar 5th, 2014, 01:32 PM
SGT Slaughter & Farm Girl
Local Time: 02:10 AM
United States Male
United-States Uneven load on mounts?????
OMG..... can't believe what "Marque" said in the post above mine! PPL actually use the sump pan as a lift point?????????? Dang people go to Mini and get the work done!
Mini_drive is offline
post #6 of 6 (permalink) Old Mar 5th, 2014, 06:46 PM
mab01uk's Avatar
Quoted: 1 Post(s)
Yes it was common for 'quick fit' tyre fitting bays to jack the old classic Mini's up from under the alloy sump/gearbox......but the engine mounts were never designed to take the full weight of the car!
mab01uk is offline
Driver side window won't go up automatically! ledfrog Second Generation Interior & Ice 3 Jan 1st, 2017 10:44 PM
Lower Engine Mount symptom sharkie First Generation Faults & Fixes 0 Mar 1st, 2014 06:18 PM
Engine Mount Top Right paulcoz33 First Generation Faults & Fixes 3 Mar 1st, 2013 09:30 AM
Driver side mirror not folding shane. First Generation Faults & Fixes 5 Jan 16th, 2013 06:25 AM
my driver side headlight points down!?? zak431 Welcome New Members 0 Nov 9th, 2012 12:38 AM
