Ignition (key cylinder) problem? - MINI Cooper Forum
post #1 of 1 (permalink) Old Apr 2nd, 2014, 06:25 PM Thread Starter
Local Time: 11:43 PM
Canada
2006 Mini Cooper, 107k. Engine continues to run even after engine is turned off and key removed. Bought a complete steering column and having them switched out. Praying that will work. Suggestions?
jaystone is offline
First generation clamshell key repair guide Valvashon First Generation Faults & Fixes 2 Jul 26th, 2016 11:48 AM
2010 Mini cooper -key fob problem Annie Second Generation MINI Cooper 3 Dec 5th, 2014 10:20 PM
Ignition Key cutting <SOLVED> SlipMat General Discussion 5 Mar 2nd, 2014 04:19 PM
Cylinder misfire problem - only when cold. mrbasstrombone First Generation MINI One 1 Jan 9th, 2014 04:52 PM
KEY Problem liamlfc11 Maintenance & MINI Care 2 Jan 16th, 2013 05:54 PM
