no tyre grip on cooper s in wet - MINI Cooper Forum
post #1 of 13 (permalink) Old Apr 6th, 2014, 09:17 AM Thread Starter
Local Time: 10:09 PM
Scotland
Pllllllzzzzz help, I need help with my tyres. I have had a mini before and the tyre grip was amazing but got a Cooper s now and the grip when cornering in the wet is awful , even a roundabout at 20mph, the car will slide on the front end and want to know a good set up to correct this , I have 205/45 R17 on the car , 2 pirreli pzero and 2 wanli tyres , I have swapped either about on each end but still same results, plz help
rusty1979 is offline
post #2 of 13 (permalink) Old Apr 6th, 2014, 10:46 AM
Hi, ive just taken off the Wanli tyres that the previous owner had put on and replaced with Vredeatein Quatrac all season tyres, these are non run flat tyres and have absolutely transformed the car, it is now sure footed and a lot more comfortable and have had no issues with loss of grip.
thechopper79 is offline
post #3 of 13 (permalink) Old Apr 6th, 2014, 11:22 AM
Quoted: 53 Post(s)
Wanli? never heard of them until now, theyre Chinese rubber.
If they were the best they'd have them on F1 cars.
The Nun is offline
post #4 of 13 (permalink) Old Apr 6th, 2014, 12:23 PM
Local Time: 09:09 PM
Hi ya
DO NOT mix and match tires run flat /non run flat and tires manufactures you need all 4 tires the same, or it will mess up the stability control which then will affect your handling. get some good quality tires all round and get the car 4 wheel aligned.
personally i do not like pirelli tires i have always found the grip poor in damp or the wet
you may also find that what you could do in your other mini you can't in the S you may have to tweak the way you drive it
marque is offline
post #5 of 13 (permalink) Old Apr 7th, 2014, 01:16 AM Thread Starter
Scotland
bad wet grip
Thanks for the replies , I have been looking at the vredestein tyres , but don't know whether to het runflats or not as I've been told I may need to notify insurance ?, but would like a softer ride
post #6 of 13 (permalink) Old Apr 7th, 2014, 11:40 AM
If they've got decent tread depth they can still be crap if they've been on the car for years and gone hard and cracked.
I wouldn't get too hung up on mixing and matching brands provided you have a matching pair on the same axle. But if you are swapping them all out then this isn't a problem.
I've just fitted non run flat Hankooks all round, the difference is very noticeable, much more compliant ride. Though the ones on before were old and cracked so anything new would have been an improvement.
Big_Nige is offline
post #7 of 13 (permalink) Old Apr 7th, 2014, 11:53 AM Thread Starter
Scotland
Cheers Nige, would love a softer ride and know how I should be able to put it round corners and it just starts drifting , think I will go for non run flat vredestein quatracs
post #8 of 13 (permalink) Old Apr 7th, 2014, 11:22 PM
Thumbs up
If you do go the vredestein quatracs the cheapest i could find were from tyreleader at £402.76 delivered from Germany, took 3 days.
post #9 of 13 (permalink) Old Apr 14th, 2014, 11:39 PM
Stooey
United Kingdom Male View Stoo Med's White Silver & Black 2nd Gen MINI Cooper Diesel Clubman Profile
Throw the Wanlis in the bin. Cheap tyres are cheap for a reason. Autocar magazine did a comparison test of Chinese brands a few years ago. The wet grip offered fell well below that of a premium European tyre. And when do you need the grip most... Yes, in the wet.
All tyres homologated for figment to BMW/Mini have the star symbol on the outer sidewall. They're designed for the car.
As for Big Nige saying you can mix brands per axle. Don't, as you'll get an imbalance of available grip.
If you want to stay on the black stuff on a sweeping right hander in the wet, and not exit stage left into that big oak tree, then take a good hard think over your tyre choice.
I investigate fatal collisions, so I know what I'm talking about.
Stoo Med is offline
post #10 of 13 (permalink) Old Apr 15th, 2014, 09:01 AM
You may investigate fatal collisions but you obviously didn't investigate my comment correctly. I said a matching pair (i.e. brand) per axle.
Now where is that Oak Tree?
Big_Nige is offline
post #11 of 13 (permalink) Old Apr 15th, 2014, 09:12 AM
Quoted: 24 Post(s)
I switched my Pirelli Euphoria runflats to Khumo Ecstas last year and they have been very good in all conditions.
The new tyre labelling system will point you in the right direction for good wet weather grip (and stopping).
The Khumo's have a higher wet weather rating than many of the 'premium' european options, which is why I eventually chose them.......their not too expensive either.
Spike
ihughes is offline
post #12 of 13 (permalink) Old Apr 15th, 2014, 11:00 AM
Quoted: 39 Post(s)
Beware - the EU wet tyre rating isonly for wet braking, not wet cornering, which was the OP's concern. For example, anyone who has driven on wet roads with winter tyres will know that they have spectacularly good wet braking but mediocre wet cornering, at best.
In general it pays to avoid getting 'specification-itis" where the quality of anything can be measured by one or two parameters, as that doesn't often say whether the item works well or not. Americans tend to focus about cornering g measured on a skid pan, which is a measure of ultimate grip and tells you nothing at all about handling. Ditto those folk who buy a camera with a high megapixel count that tells you nothing about the lens in front of it.
Angib is offline
post #13 of 13 (permalink) Old Apr 16th, 2014, 09:53 PM
Stooey
Good to see sarcasm is alive and well on this site!!
Stoo Med is offline
2014 MINI Cooper Hardtop Revealed AutoGuide.com MINI News 15 Apr 23rd, 2015 04:15 PM
Learning to Drive MINIs the Way John Cooper Intended AutoGuide.com MINI News 0 Jul 26th, 2013 07:12 PM
A Look Back at the Three Generations of the Mini Cooper & Cooper S mab01uk MINI in the Media 2 Mar 10th, 2013 11:11 AM
Cooper S 17" tyre pressure seems high Franzz Second Generation MINI Cooper S 2 Feb 26th, 2013 04:10 PM
Mini Cooper r53 acs, abs and tyre light rossib86 General Discussion 4 Jan 13th, 2013 09:23 PM
