Tyre Warning Light Problem - MINI Cooper Forum
post #1 of 3 (permalink) Old Apr 26th, 2014, 12:48 PM Thread Starter
Local Time: 10:56 PM
Yesterday my wife noticed a red warning light on the dash, it turned out to be the tyre pressure (or loss of it) and we found that the rear offside tyre of the Clubman had a slow puncture. A trip to the local tyre repair shop fixed that but the warning light remained on. The mechanic said it needs to reset and would go off afer a few miles.
However after some 70 miles the light is still on. Can anyone suggest a reason? Thanks!
billy.batson is offline
post #2 of 3 (permalink) Old Apr 26th, 2014, 12:58 PM
I'm only newbie but 2 things I would try first is make sure all the tyre pressure is the same and press the reset button, worked for my Mini Cooper light went off after 50 yards
Dreadlocks is offline
post #3 of 3 (permalink) Old Apr 26th, 2014, 01:02 PM
Local Time: 11:56 PM
Quoted: 53 Post(s)
Youve not reset it properly I would think? unless they had over inflated your repaired one?
The system works on wheel speed/revs so ideally they all need to be going round at the same speed so be the same diameter.
The Nun is offline
Intermittent Oil Warning Light Problem andyjshaw Second Generation MINI Cooper S 7 Nov 17th, 2015 01:22 PM
joeb585 Warning Light problem joeb585 Welcome New Members 6 Mar 24th, 2014 03:20 PM
Battery warning light, overheating warning light LizzyG Second Generation Faults & Fixes 2 Jan 2nd, 2014 06:30 PM
flat tyre warning light gar1380 First Generation MINI Cooper S 2 Mar 29th, 2013 11:48 PM
Pls help re tyre pressure issue (+ warning light)... halesowenmum Wheels, Tyres & Brakes 8 Jan 25th, 2013 10:39 PM
