Daylight Running Lights - MINI Cooper Forum
post #1 of 4 (permalink) Old Apr 29th, 2014, 10:40 PM Thread Starter
Local Time: 08:35 PM
Canada
I'm in Canada and I have a 2012 Cooper S with the standard halogen headlights. When the car is running with the headlight switch off, the headlights are on low beam, the running/fog lights are on as well as the back lights.
If I buy the LED daytime running lights do I have the option somehow to turn off the headlights and only use the LED daytime lights. Reason I'd like to get the headlights off is that with more powerful halogen bulbs I use the UV turns the plastic cover a yellow pretty quick along with the bulbs not lasting very long.
Do UK cars have all their lights go on as soon as the motor is on too ?
Thanks guys (& girls)
jackski2 is offline
post #2 of 4 (permalink) Old Apr 30th, 2014, 03:10 PM
Local Time: 11:35 PM
Quoted: 40 Post(s)
Discussion on American Mini forums suggest that the LED DRLs cannot be used in Canada - or at least they cannot be used as DRLs without headlights since Canadian Minis are programmed to always have their headlights on. It might be possible to overcome the programming if you access the ECU directly with NCS Expert, but I haven't seen anyone report success in doing this and it's getting into fairly serious modification territory - how much for a new ECU if the programming goes wrong?
As far as I know, Canada is the only place (apart from Sweden?) where headlights were compulsory - European Minis can choose via the stalk programming whether to use headlights as DRLs.
Angib is offline
post #3 of 4 (permalink) Old Apr 30th, 2014, 08:08 PM
Quoted: 25 Post(s)
With all the Moose running about on the road over there it's a good idea to have their lights on all the time
drozd is offline
post #4 of 4 (permalink) Old Apr 30th, 2014, 08:22 PM
Local Time: 12:35 AM
Cyprus Male
So to get this right: you want to disable the headlight from being on all the time, so the DRL's work as expected?
In any case this behaviour should be controllable with NCSExpert. The question is, whether it would be legal to do so...
Having seen the videos of the installations, the LEDs would probably be in the "driving mode" (semi-circle) all the time and never go into full-circle mode (when all other lights are off).
alexcannas is offline
LED Daytime running lights - retro fit GimpyNuNu Second Generation MINI Exterior 8 Aug 31st, 2015 02:35 PM
Automatic headlights and daytime running lights GimpyNuNu Second Generation MINI Exterior 8 Jun 4th, 2014 03:48 AM
F56 (2014) Mini - Daytime Running Lights Gazparc General Discussion 3 Dec 14th, 2013 08:46 AM
LED Running Lights MiniBK General Discussion 5 Oct 6th, 2013 08:37 AM
R56 angel eye headlights - day time running lights? JD_R56 Second Generation MINI Exterior 2 May 9th, 2013 06:56 PM
