Replacing front door speaker r50 5.25" suggestions? - MINI Cooper Forum
post #1 of 5 (permalink) Old May 6th, 2014, 02:39 PM Thread Starter
Local Time: 01:45 AM
Hi guys so it seems my front door speaker has blown on the passenger side front door. I've tried to replace my speakers before but I did purchase adapter rings so the speaker wouldn't fit. Now I'm thinking of buying some aftermarket speakers alongside the adapter rings my speaker size is 5.25 " any suggestions?
Can I simply wire the existing wire to the new speakers also? Thanks!
Budget - 35-40 max.
Jonastokes is offline
post #2 of 5 (permalink) Old May 6th, 2014, 04:20 PM
Local Time: 12:45 AM
United States Male
Pioneer TS-G1344R 5.25" Car Speakers - Walmart.com[/url] for the money you have this is perfect. Really it comes down to how much money you have. you may need a small amp if you use higher powered door speakers.
TheGypseDanger is offline
post #3 of 5 (permalink) Old May 7th, 2014, 12:06 AM
Hi ya
You can use the existing wiring.
You can go up to 6 1/2" fronts if you want, just remember use the adaptors on both sizes and get a shallow speakers you may need a harness adaptor
Just keep an eye on your speaker wires when the window operates it's close in there
All good car audio places will have this stuff you need I have used dynamic car sounds they should have something in your budget range
marque is offline
post #4 of 5 (permalink) Old May 10th, 2014, 05:55 AM
Local Time: 07:45 PM
I recently replaced my front speakers. I have a 2002 cooper s. The old speaker was kind of floating with fins. I cracked the old crappy speaker out and mounted the new speaker to it. Fit perfectly.
rnlble is offline
post #5 of 5 (permalink) Old May 10th, 2014, 07:33 AM
Ollypop0
Hi
A good option could be a set of Harman Kardon speakers out of a scrapped mini. There's always a few knocking about on eBay. They're very good speakers and give a great sound quality.
Ollypop0 is offline
