problems with my steering - MINI Cooper Forum
post #1 of 6 (permalink) Old May 11th, 2014, 09:33 PM Thread Starter
Local Time: 02:34 PM
Unsure if we have a problem with the steering on our mini one, it is stiff-not heavy.You cannot rotate the wheel with fingers or one hand.So confused if this is normal?Just been for mot and the mechanic did say they have problems with power steering pumps, and the steering was a bit stiff but not heavy so he was confused.On the pipework there was a damp spot which he says could be loosing pressure but we have had the car for 12 months and the fluid is topped up, dosnt deem to have lost any.It not like driving a tractor but not very fluid?
plugy is offline
post #2 of 6 (permalink) Old May 11th, 2014, 09:48 PM
Local Time: 01:34 PM
Hi ya
What year is your mini.
I know it's a sill question but your tire pressure are correct.
marque is offline
post #3 of 6 (permalink) Old May 12th, 2014, 10:18 AM
My 02 plate had a steering Issue would go rock solid. Look up watchdog mini power steering issue in google as richard grant did a piece on the problem about a year ago when his daughters went wron
Beaneyman is offline
post #4 of 6 (permalink) Old May 12th, 2014, 10:18 AM Thread Starter
Yes tyres ok, ball joints fine etc as just had mot and as we said even the mechanic commented on it being stiff, not heavy not light but in between which puzzled him?
plugy is offline
post #5 of 6 (permalink) Old May 12th, 2014, 04:18 PM
United States Male
Ok so I am having the same issue just different format. One day my power steering works, the next it does not (Even though the steering is really stiff and heavy I kind of like it, reminds me Im a man). Sometimes when coming off the motorway the steering will go stiff until I restart the car. I have tried using electrical parts cleaner and a air shop hose to clean and blow out the connectors. The issue is less frequent, but it still happens which means I still have an issue. I have seen some people taking the power steering out completely? An suggestions from our brothas and sistas @mini2?
TheGypseDanger is offline
post #6 of 6 (permalink) Old May 12th, 2014, 06:25 PM
mab01uk's Avatar
Quoted: 2 Post(s)
You need a new power steering pump, lots of info here:
Power Steering Pump replacement - Mini Cooper Register Forum
mab01uk is offline
Tags: ,
Power Steering Rack & Pinion Frustration VerticalMinded First Generation MINI Suspension 4 Jan 28th, 2014 08:14 PM
Power Steering problems :( Shelley B First Generation MINI Cooper S 5 Feb 15th, 2013 12:13 PM
Power and steering problems Beemer_twins First Generation Faults & Fixes 8 Dec 13th, 2012 04:28 PM
Power Steering pump on the blink...? cooper357 First Generation Faults & Fixes 8 Aug 21st, 2012 10:26 PM
