Piston Ring clearances - MINI Cooper Forum
post #1 of 1 (permalink) Old May 12th, 2014, 03:48 AM Thread Starter
Local Time: 06:49 AM
Philippines
DIY Piston Ring clearances
Hello,
I am rebuilding a cooper engine. I ordered a set of "standard" size pistons and rings. When the set came, the compression rings have the correct clearances, but the oil scraper rings seem to be for the first over size.
Has anybody experienced this? is there anyone that can give me an idea what the clearance should be for the oil scraper ring?
Hope someone can help.
dayuyao is offline
stuck piston ring scenario genik Second Generation Faults & Fixes 1 Apr 5th, 2014 04:13 PM
How to replace the cigarette lighter luminous ring MangaGal First Generation Interior & Ice 7 Mar 30th, 2014 04:09 AM
Help finding piston ring 04JCWmini Maintenance & MINI Care 2 Sep 29th, 2013 08:40 PM
Antenna rubber ring thing MiniMelinCA Second Generation MINI Exterior 3 Sep 20th, 2013 09:13 PM
rear brake caliper piston dustcover replacement mini_scotsguy Wheels, Tyres & Brakes 0 Aug 15th, 2012 09:25 PM
