2003 mini cooper s HK amp - MINI Cooper Forum
post #1 of 2 (permalink) Old May 21st, 2014, 07:28 PM Thread Starter
Local Time: 08:54 AM
Hi all- I am new to this forum and just picked up the car a few days ago. Zero sound at all coming from the radio. Everything I have read is pointing me towards the Harmon Kardon amp being blown. That being said, can anyone verify before I buy a new head unit that all I will need to do is get that to avoid spending hundreds on a replacement amp? Thanks for the help!
MountRussMoore is offline
post #2 of 2 (permalink) Old May 21st, 2014, 09:01 PM
Hi ya
If you want to check the head unit disconnect the plugs on the amp and follow the picture
You can jump the connector so at least you have the fronts working.
Check all the fuses I think there was one behind the stereo to for the amp as well as the fuse box
This link may help to
http://www.northamericanmotoring.com...p-failure.html
marque is offline
2014 MINI Cooper Hardtop Revealed AutoGuide.com MINI News 15 Apr 23rd, 2015 03:15 PM
New 14 plate Mini Cooper SD Coupe Nightmare Kickboxkel Welcome New Members 7 Apr 4th, 2015 12:33 PM
Mini Cooper S Seat Heater Fire Paul.Armstrong First Generation Faults & Fixes 0 Apr 29th, 2014 02:08 PM
