cooper overheating - MINI Cooper Forum
post #1 of 3 (permalink) Old May 24th, 2014, 03:28 PM Thread Starter
Local Time: 07:52 AM
England Female
cooper overheating
My 2006 cooper is overheating, the left hose from radiator is cool and showing no pressure but the one on the right at the rear is boilng, have bled from both screws but to no avail, can any one help. My car is my life.
rabbitcoop is offline
post #2 of 3 (permalink) Old May 24th, 2014, 10:41 PM
Local Time: 06:52 AM
Hi ya
What work has been carried out
You may have a duff thermostat, do you have access to a scan gauge or diagnostic tool that can read the coolant temp.
When your filling the system make shore to run the heating at half fan and full heat. This will bleed this part of the system.
You may need to pop out the thermostat and check it, sometimes they take a while for the thermostat to open.
Hope this helps
marque is offline
post #3 of 3 (permalink) Old May 24th, 2014, 10:56 PM
heathwebbo's Avatar
Yes sounds like thermostat to me or maybe a blockage in the rad. As soon as the engine reaches operating temperature the thermostat opens & the top hose should start getting hot
heathwebbo is offline
2014 MINI Cooper Hardtop Revealed AutoGuide.com MINI News 15 Apr 23rd, 2015 04:15 PM
2014 MINI Cooper S Revealed in Spy Photos AutoGuide.com MINI News 14 Jan 13th, 2015 08:58 PM
Cooper. Cooper s or cooper sd coupe morgs18 General Discussion 3 Feb 7th, 2014 11:31 AM
Learning to Drive MINIs the Way John Cooper Intended AutoGuide.com MINI News 0 Jul 26th, 2013 07:12 PM
A Look Back at the Three Generations of the Mini Cooper & Cooper S mab01uk MINI in the Media 2 Mar 10th, 2013 11:11 AM
