Convertible rear side windows - MINI Cooper Forum
post #1 of 7 (permalink) Old Jun 6th, 2014, 09:04 PM Thread Starter
Local Time: 05:16 AM
Quoted: 81 Post(s)
It's been bugging me ever since I have owned the car and at times I think I have sorted it, but unfortunately not.
When you lower the roof occasionally neither rear side window come back up, or just one does, and the same when you raise the roof.
If you lower all the side windows and raise them holding the respective button in for 5 seconds after they have stopped moving it seems to be fine for a little while, but eventually it will play up again.
What can I do about it? It's so annoying, has anyone else had a similar problem and if so do you live with it or how did you get it fixed?
k3fus is offline
post #2 of 7 (permalink) Old Jun 7th, 2014, 04:50 PM Thread Starter
Quoted: 81 Post(s)
87 views and no help!?
k3fus is offline
post #3 of 7 (permalink) Old Jun 7th, 2014, 04:56 PM
Caveman's Avatar
Local Time: 06:16 AM
Quoted: 83 Post(s)
This thread belongs in the appropriate Faults & Fixes forum.
Caveman is offline
post #4 of 7 (permalink) Old Jun 7th, 2014, 05:13 PM
Local Time: 04:16 AM
Hi ya
It's most probably a bad relay there are a few behind the trim panel by the rear seats left hand side, but I think there are one or two under the right to.
Have a look at this link scroll down to the interlock relays I think that's where your problem is
http://www.realoem.com/bmw/partgrp.d...id=48015&hg=61
Sometimes they come loose with the vibration causing bad connections and intermittent faults.
Really you need to run a proper diagnostic on it using the bmw dis this will narrow it down properly or you may find you just case your self round.
If you can get a Bentley manual from Amazon there will worth the money but get the one with diagnostic section
Hope this helps
marque is offline
post #5 of 7 (permalink) Old Jun 7th, 2014, 10:11 PM Thread Starter
Quoted: 81 Post(s)
Where no one hoes!
Originally Posted by marque View Post
Hi ya
RealOEM.com * Diagram Selection
Hope this helps
Thanks for your help, I have a copy of dis but not sure how to use it.
k3fus is offline
post #6 of 7 (permalink) Old Jun 7th, 2014, 10:50 PM
Hi ya
This might help
http://www.motor-talk.de/forum/aktio...hmentId=722208
If you have the lead and the dis and have loaded it all up and can get it to connect you basically want from page 35/36 onwards. Select your model and the.n follow the steps.
Once you get to page 41 look for a x next to the title for the convertable then you can click on the green arrow and follow the task and test.
You can't do any harm with the dis if in doubt quit is a very good tool, the only thing I would say is if you have an x run a quick delete to clear the faults as they may be an old stored fault and you my start to chase a problem that is not there if you follow.
The more you use it the more you will get used to it, you can then go in to component activations an do tests.
Will try to dig out some stuff for you you tube os a good source of info
http://bmwcoders.com/forum/bmw-gt1-o...-tester-one-2/
http://www.bmw-driver.net/forum/showthread.php?t=41062
http://www.motodok.com/Documentation...-Diagnosis.pdf
marque is offline
post #7 of 7 (permalink) Old Jun 8th, 2014, 01:14 PM Thread Starter
Quoted: 81 Post(s)
Thanks I appreciate you taking time to share that.
k3fus is offline
Convertible rear sensor replacement k3fus First Generation Faults & Fixes 1 Feb 16th, 2014 04:17 PM
convertible heated rear window not working Redcooperclubman First Generation MINI Convertible 2 Dec 26th, 2013 02:56 PM
Rear Brake Disc corroded on inboard side jasonofbillinge Wheels, Tyres & Brakes 1 Jun 9th, 2013 05:03 PM
HELP - Rattle/ Knocking Noise from rear passenger side wheel. thegreensnot Second Generation Faults & Fixes 8 Dec 10th, 2012 07:21 AM
Rear Bumper for Mini Convertible Dazzahooz General Discussion 2 Sep 26th, 2012 11:04 PM
