Cooper S Convertible Top Question - MINI Cooper Forum
post #1 of 1 (permalink) Old Jun 9th, 2014, 08:55 PM Thread Starter
Local Time: 06:09 PM
United-States Cooper S Convertible Top Question
I have a 2010 Cooper S Convertible and there are small rubber/plastic grommets at the bottom of the convertible top inside the trunk space (behind the rear seats) that fasten against the inside metal of the car to keep the top tight where the top material meets the metal behind the rear windows. Well one of the grommets broke and it's physically sewn into the top material. I called a Mini dealer and short of wanting to replace the top, they recommended finding a convertible top repair shop. Has anyone had this problem and what did you do? Seems odd to have to spend $2,000 to replace the entire top over a plastic part that probably costs $5. Thanks!
spostek is offline
Convertible top wire bow broken crystala1966 First Generation MINI Convertible 1 May 13th, 2015 07:17 PM
2001 Cooper top strut problems cuda67 First Generation MINI Suspension 16 Jun 28th, 2014 05:26 PM
Convertible top not coming down - not the usual symptoms colinu First Generation Faults & Fixes 3 May 24th, 2014 10:40 PM
Cooper S Hardtop or S Convertible? ca13818 General Discussion 3 Feb 23rd, 2014 04:19 PM
