Convertible Roof wont work - MINI Cooper Forum
post #1 of 3 (permalink) Old Jun 12th, 2014, 01:34 PM Thread Starter
Local Time: 08:11 AM
Unhappy Convertible Roof wont work
I have an 04 Convertible, before winter the roof was struggling to close, we managed to manually close it and now it is spring/summer i went to open it and there is nothing coming from the roof. The windows button is working perfectly however the roof ones are getting nothing.
My first step was for a mechanic friend to test all my fuses and they were all fine
We then checked the parcel shelf was in right position and it is
We then moved onto checking if there was enough hydraulic fluid and its fine
We did a quick inspection of the framework which was only rebuilt afew years ago before i bought it and we could see no cracks or issues
We then thought what about the switch so i bought a new one and still we have nothing.
The mechanic friend then ran power through the motor and it was working.
i am stumped and would appreciate some help as i know dealers are very expensive
GreenMachineVicky is offline
post #2 of 3 (permalink) Old Jun 12th, 2014, 05:24 PM
Hi ya
When you say you checked the fuses
which ones did you check there is a fuse box the footwell and also the engine bay both these locations have fuses for the roof, also there are fuses on the underside of the engine bay fuse box.
I will find a link for fuses for you
http://www.mini2.com/forum/maintenan...th-points.html
Hope this helps
marque is offline
post #3 of 3 (permalink) Old Jun 13th, 2014, 06:12 AM
Local Time: 09:11 AM
Quoted: 53 Post(s)
I know dealers can be expensive but youve already bought a switch it doesnt need by guessing too?
The Nun is offline
2004 Mini Cooper Convertible Roof Problem Wharthog First Generation Faults & Fixes 8 Apr 13th, 2014 07:14 PM
2009 possible leaking convertible roof Wall7474 Welcome New Members 1 Jan 18th, 2014 06:51 PM
convertible roof - need wiring diagrams please SRDTVR First Generation Faults & Fixes 4 May 3rd, 2013 06:53 AM
Convertible roof maintenance Medox73 First Generation MINI Convertible 4 Jan 13th, 2013 02:27 AM
54 convertible roof wear: is there a solution? Mervthemini First Generation MINI Convertible 0 Jul 26th, 2012 09:51 AM
