Lucky escape! - MINI Cooper Forum
post #1 of 2 (permalink) Old Jun 13th, 2014, 09:05 AM Thread Starter
Local Time: 04:07 AM
England
Lucky escape!
I bought a '54 plate MCS convertible from a local dealer 3 months ago. Last month, I had a couple of tyres fitted, and 4-wheel alignment done. They spotted that the front wishbone bushes were worn, said to get them changed, then bring car back.
Car was still under warranty, so supplying dealer got the local BMW specialist to replace the bushes, and also fix the airbag light (new battery cable fitted).
Yesterday, I took the car back to the tyre shop to finish the alignment. They noticed that the bracing bars that run from the sills to the rear subframe were loose. All the bolts were showing about 15mm of thread, and the one in the driver's sill had fallen out!
Looks like the specialist had dropped the bars and brackets to feed the new cable through, and forgot to tighten the bolts afterwards.
If the tyre place hadn't spotted this, eventually the whole lot would've dropped off, and I dread to think about the potential damage!
clockworks is offline
post #2 of 2 (permalink) Old Jun 13th, 2014, 04:54 PM
Quoted: 53 Post(s)
Hmmm not good is it, I suppose we do put a lot of trust in those who do jobs for us, they probably went for a tea break halfway through the job and got side tracked.
The Nun is offline
2nd time lucky? tomo1982 Welcome New Members 0 Jan 19th, 2014 04:30 PM
MINI driver's close escape from helicoptor crash mab01uk MINI in the Media 0 Jan 16th, 2013 06:25 PM
