Turbo or Supercharge? - MINI Cooper Forum
post #1 of 3 (permalink) Old Jun 17th, 2014, 04:07 PM Thread Starter
Local Time: 02:23 PM
Hi, new member here, not got a Mini yet but am in the process of looking. I quite fancy an older supercharged version but realise I'm going to have to accept than the mileage will more than likely be higher. Ignoring all other issues for now, like wear and tear, would I be better to stretch the budget and go for later model with a turbo. Are the turbo engines any better?.
Like to hear your opinions.
Regards Nigel
Padsdad is offline
post #2 of 3 (permalink) Old Jun 17th, 2014, 04:19 PM
Caveman's Avatar
Local Time: 03:23 PM
Quoted: 83 Post(s)
The N14 engine in Euro R56 MCS models built through February 2010 had quite a few problems (search "death rattle" "coking") whereas the only real worry with the 1st Gen MCS engine is replacing the supercharger at mileage above 100K.
Caveman is offline
post #3 of 3 (permalink) Old Jun 17th, 2014, 08:11 PM
Local Time: 01:23 PM
United States Male
supercharged Mini's
I just bought a 2006 "S" that is supercharged. First, I'm not new to supercharger performance and maintenance. I do find it incredible that there is limited info out there about oil & belt changes on stock equipment. These two maintenance items can increase serviceable life on a supercharger. I don't like the fact that the entire front end has to come off to do supercharger maintenance.
I've also been reading the info on supercharger vs turbocharger. The increase in horsepower from one to the other is minor 4 HP for stock equipment. I can get into plenty enough trouble supercharged !
Is there any comprehensive data in print about stock supercharger maintenance?
steeleyscotty is offline
DIY: Changing the orange turbo seal MiniDeLux MINI Cooper Diesel 1 Dec 30th, 2014 11:43 AM
No Turbo boost,fault code 2884 charge air pressure control deviation Horsepower Jonny Welcome New Members 0 Jun 9th, 2014 06:43 PM
Soot around turbo and tractor noise during left-hand cornering sebster MINI Cooper Diesel 14 Aug 19th, 2013 07:58 AM
2007 R56 MCS Turbo blowing/damaged Sharkn3t Second Generation MINI Cooper S 6 Jan 23rd, 2013 10:02 AM
Loose turbo inlet pipe; beware Jonnyfive Second Generation Faults & Fixes 1 Aug 8th, 2012 02:06 AM
