My drivers main beam bulb will not go out - MINI Cooper Forum
post #1 of 3 (permalink) Old Jun 18th, 2014, 08:11 PM Thread Starter
Local Time: 09:05 PM
Hi there everyone i was wondering if anyone has had this problem before i went to start my car one morning and the battery was flat so i went to buy a car battery booster pack which my car started up first time but for some reason my drivers side main beam light will not turn off some times it stays on or it will flash off and on anybody have a clue thanks .
Rossco1988 is offline
post #2 of 3 (permalink) Old Jun 19th, 2014, 06:25 AM
Quoted: 53 Post(s)
Why did you buy a booster pack? did you know the battery was a good one, fairly recent, so knew it cant be just a battery fault?
MINI electrical systems can go haywire if the battery voltage keeps dropping below a certain point.
The Nun is offline
post #3 of 3 (permalink) Old Jun 19th, 2014, 12:02 PM
Cyprus Male
Assuming that you have Xenon lights, it could be the Xenon bulb itself or the ballast. Also, if you have a car with a sunroof, check for water ingress down to the FRM ECU which is located in the passenger side footwell.
If you have access to a BMW scan tool (not a generic one mind you), then you should check for errors on the FRM. The computers are capable of logging such intermittent errors.
I had a similar problem on my 07 R56, which disappeared after fixing the sunroof drains. Go figure...
alexcannas is offline
Help Headlights Main Beam Flickering BillyJ_110 Second Generation Faults & Fixes 2 Jan 27th, 2013 05:30 PM
