Changing Rad on 02 Cooper - MINI Cooper Forum
post #1 of 5 (permalink) Old Jul 3rd, 2014, 07:58 PM Thread Starter
Local Time: 10:59 AM
United-Kingdom Changing Rad on 02 Cooper
Have a leak from radiator on my 02 Cooper, do I change it myself or get a garage to do and is it advisable to change anything else while changing the rad?
maffup is offline
post #2 of 5 (permalink) Old Jul 4th, 2014, 06:40 AM
heathwebbo's Avatar
Local Time: 09:59 AM
It all depends how good you are with spanners, you would have to take off the front bumper & crash bar first to get to it then its relatively easy to remove & replace. It will then need bleeding to make sure all the air is removed from the system.
Some change the thermostat housing & thermostat at the same time as they can sometimes leak
heathwebbo is offline
post #3 of 5 (permalink) Old Jul 4th, 2014, 03:22 PM
Hi ya
Pretty simple job if you are competent with the tools bumper and carrier off and your under trays will need to be removed to
just use the correct coolant you can get this from halfords
Halfords | Comma G48 Antifreeze and Coolant Conc 2L
50/50 mix
I would personally check your first stage fan resistor while you are there.
Repair Kit Resistor Radiator Fan Fits Mini Cooper | eBay
Take your time to bleed it and make shore you have the Incar heater on high and fan on med when you are bleeding it
http://www.mini2.com/forum/maintenan...screw-plz.html
Service mod
Girls's Guide to Removing the Bumper, Bumper Carrier, and the Modular Front End - North American Motoring
Hope this helps
marque is offline
post #4 of 5 (permalink) Old Jul 7th, 2014, 05:16 PM Thread Starter
Thanks very much I'll give it a go at the weekend
maffup is offline
post #5 of 5 (permalink) Old Jul 7th, 2014, 05:31 PM
JohnnyC's Avatar
Quoted: 164 Post(s)
Wow, undoing the bumper adjustment bolts to remove the bumper
What's the point of that?
JohnnyC is online now
Tags: , ,
CVT Transmission Failure slaybalj First Generation CVT & Automatic 143 Jun 10th, 2016 02:24 AM
Changing wheels on MINI COOPER R50 Jonastokes General Discussion 0 Apr 9th, 2014 11:11 AM
Changing spoiler from cooper to cooper s BeccaRoberts04 Second Generation MINI Exterior 1 Mar 21st, 2014 05:23 PM
mini cooper 2002 clonking felt through pedals when pulling away and changing gear? juddyboy! Welcome New Members 2 Apr 20th, 2013 09:13 PM
Changing CD player in 2003 cooper s, which loom?? Lawrence1584 General Discussion 2 Nov 16th, 2012 04:44 PM
