supercharger question - MINI Cooper Forum
post #1 of 3 (permalink) Old Jul 3rd, 2014, 11:00 PM Thread Starter
Local Time: 01:50 PM
Canada Male
I am looking at a 2007 mini cooper,no s. Is there an aftermarket supercharger available for this or am I destined to a 2006 or older?
erictye is offline
post #2 of 3 (permalink) Old Jul 4th, 2014, 06:32 AM
heathwebbo's Avatar
Local Time: 06:50 PM
A standard cooper engine has a lot of different parts to the cooper s engine so fitting an aftermarket supercharger would involve loads of work & cost. If you want a supercharged cooper s you would be better off buying a 2006 or older
heathwebbo is offline
post #3 of 3 (permalink) Old Jul 4th, 2014, 03:41 PM
Hi ya
If your car is a 2007 cooper it's a very good chance it's a gen 2, only the gen 1 r52/53 mcs came with an sc.
the gen 1 non MCS engines are weak and would need loads of internal work and electronics as you would be doubling the hp.
Gen 1-2 totally different engine as well anything is possible but cost will be massive
The gen 2 mcs had a turbo, you could do a turbo conversion to your cooper but it would not be as good as an MCS . You would be better off selling yours and buying an MCS much cheeper and more reliable.
marque is offline
Run Flat Question samowens Wheels, Tyres & Brakes 1 Jul 13th, 2013 09:09 AM
Bought my first Cooper S, have a supercharger question Ellies Mini General Discussion 4 Apr 1st, 2013 08:38 AM
Dim Xenon Headlights / Supercharger Question chumley69 General Discussion 5 Mar 26th, 2013 03:55 PM
When should I use supercharger? rugrat General Discussion 5 Feb 21st, 2013 11:35 AM
Used or Recon Supercharger MCS JCW krispee First Generation MINI Tuning 5 Sep 28th, 2012 09:58 PM
